2-axis joystick object
Here is a nice object for the Parallax 2-axis joystick. The joystick is measured with RC decay and you will need 2 ceramic capacitors (.01uf) to use the object. Operation instructions are inside the code. Have fun!
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Micro
''This is started in a new cog when Start is called, but to save a cog you can
''call it directly and get the values with get_x and get_y
i := 1
repeat ************* forever
If I call it directly, it will never return. I also don't understand what you are doing with the local variable i.
John Abshier
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
