AES 128 with external chip/module ? — Parallax Forums
Paul_DlkPaul_Dlk Posts: 19
edited 2010-07-13 12:18 in Propeller 1
I have a prop application that reads a block of 'encrypted' data from an Sd card. The propeller then decrypts this data. The encryption scheme is very simple as the data is of nominal value and was only meant to prevent a casual onlooker from seeing the data.
However the project is developing and the 'value' of the data is now increasing and I therefore have to employ a stronger encryption method. I know very little about encryption methods and I know less about the maths used for encryption.
Is there a chip/module that can receive, via I2C or SPI, a small block block of encrypted data (10 to 20 characters) and decrypt it using a key that is securely burnt into the chip and send it back to the prop.
I believe that the best encryption method is AES 128 (or 192, 256), is this correct?
Paul
Post Edited (Paul_Dlk) : 6/20/2010 12:13:10 PM GMT
  • Paul_DlkPaul_Dlk Posts: 19
    edited 2010-06-21 07:19
    I have come across the concept of a Trusted Platform Module (TPM), has anyone worked with a TPM in conjunction with a prop? Can a TPM do what I need it to do, or is it simply a secure vault for keys?
    Paul
  • heaterheater Posts: 3,370
    edited 2010-06-21 10:57
    Why not use an AVR or PIC or some such cheap, small micro-controller?
    Put the encryption algorithm on there with the key all locked away behind the code protection fuses. Transfer data in and out via I2C, SPI, UART whatever.
    As for the algorithm, that depends how secure you want to be, how fast it needs to be and how big the available code space is.
    The RC4 algorithm for example is quite small and simple and will fit in small AVR/PICs. RC4 is used in WEP and SSL. Read about RC4 here en.wikipedia.org/wiki/RC4 which also has an example implementation in C.
    Also on wikipedia you will find the TEA and XTEA algorithms both are small and there are C code implementations. en.wikipedia.org/wiki/Tiny_Encryption_Algorithm and en.wikipedia.org/wiki/XTEA.
    Bear in mind in mind that a lot of the security of any algorithm can be compromised by poor implementations, WEP for example.
    You might have to say more about your requirement. For example does the user, that you don't want to be able read the data, have physical access to the Prop/crypto hardware? If so then he has access to the decrypted data stream anyway.
    edited 2010-06-21 20:24
    Thanks Heater,
    I'll look into the PIC option although I have practically zero experience with the PIC and I have to get something done pretty soon. I was hoping that an off the shelf solution might be available.
    I will do some research on encryption for the PIC and how i might get data into it and out of it.
    Paul
  • BuildThingsBuildThings Posts: 31
    edited 2010-06-21 22:44
    Paul,
    I have done some work with some of the Maxim products that are designed for secure storage. I have interfaced these with the Prop, and have implemented X509 certificate storage and signing. Check out the information on their website. www.maxim-ic.com/datasheet/index.mvp/id/4982
    edited 2010-07-09 18:17
    Does anybody know how I can get my hands on a full datasheet for the DS2460 ? Its proving rather difficult to contact anybody in Maxim who is willing to give me an answer. :-(
    is there any other chip that can provide a strong encryption engine that is easy to integrate with a propeller?
    Paul
  • hover1hover1 Posts: 1,929
    edited 2010-07-09 18:39
    Did you find this one?
    http://datasheets.maxim-ic.com/en/ds/DS2460.pdf
    Looks to be the full data sheet.
    Jim
    Paul_Dlk said...
    Paul
    edited 2010-07-09 18:41
    Hi Hover,
    thats the 'Abridged Version'
    Thanks anyway
    edited 2010-07-09 18:59
    Given that the encrypted data is coming off of the SD card and the decrypted plain "text ends" up on the Prop, or at least passes through it, I might assume that the Prop is in the hands of a trusted person or in an environment safe from those you would rather not have access to the plain text.
    In that case why not put the decryption algorithm and keys on the Prop itself?
    Use Catalina, ICC or even my Zog interpreter to run the decryption code compiled from C source.
    There is an example of the Prop running the xxtea algorithm compiled from the C code you find on wikipedia in the Zog project. I'm sure Catalina will compile that for the Prop and have it running as well and faster.
    edited 2010-07-09 19:35
    Hi Heater,
    yes the plain text ends up on the prop, and is promptly printed for all to see.
    The data is currently encrypted on a pc/server using a very simple homespun algorithm. The result is transmitted via the internet and stored on an SD card. and placed in the end product containing the prop. The prop reads off blocks of data (8 to 16 bytes at a time), decrypts it and sends to a printer.
    My problem is that the encryption is not strong enough to send via the internet. I need to use AES 128 or stronger and I need to keep the keys secret, therefore I can't store it on the props eeprom.
    I thought that there might be a hardware solution which contains the key and can:
    A) sit between the SD card and the prop and decrypt the data in real time from the SD card
    OR
    B) be connected to the prop via SPI or I2C , whereby the prop sends the encrypted data to it and receives the decrypted data from it.
    Paul
    edited 2010-07-09 20:27
    Ah OK.
    Depending on your level of paranoia, the actual threat risk and the value of the data there are many solutions.
    Personally I would not be hung up on the "strength" of any particular encryption algorithm. There are many ways secure systems have been broken and data sucked out of them without actually cracking the algorithm used. Don't forget that in your application the keys are in the hands of whoever is using this device even if they are hiding inside some chip.
    I would be inclined to put the decryption code and the keys into a PIC or AVR hiding in the FLASH and EEPROM respectively. Use the program security fuses.
    I'd go for the xxtea algorithm.
    You might want to arrange for the possibility to change the keys if you expect to have physical access some times.
    Have a look at the simple project for SD cards that you could adapt for this job. Just pump the data out of there to the Prop for printing etc. www.captain.at/electronic-atmega-mmc.php
  • evanhevanh Posts: 16,766
    edited 2010-07-12 00:52
    I'm guessing this is for a dongle. As in each key/pair is sold on a per license basis and it is usable by the customer but the customer does not know what the key is other than this dongle they have to plug in to get the correct data flowing, right?
  • LeonLeon Posts: 7,620
    edited 2010-07-12 01:42
    Microchip has AES code available for 16-bit PICs:
    www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en537998
    It should run on the smallest PIC24 (14-pin). You have to be in a country approved by the USA to buy it.
    Leon Heller
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 7/12/2010 1:55:07 AM GMT
    edited 2010-07-12 08:15
    @Leon, thanks for the link, it is helpful but I have no real experience of PIC prgramming and as this project is time critical I don't really have the time to learn, I'm considerring 'buying in' the expertise to help with this. See my latest thread - http://forums.parallax.com/forums/default.aspx?f=25&m=468341
    Paul
    edited 2010-07-12 09:04
    I'll pay Microchip the princely sum of $5, download the software (assuming I get approval to use it), see what is involved, and give you a quote. I don't think there is very much work involved.
    I've downloaded it. Their system knows that I'm in the UK, rather than Cuba or Iran. You aren't somewhere like that, are you?
    The code builds OK with the C30 compiler, the actual AES code is written in assembler. I should be able to test it with the simulator.
    Leon Heller
    Post Edited (Leon) : 7/12/2010 9:35:36 AM GMT
    edited 2010-07-12 09:43
    No need to encumber yourself with Microchip's petty restrictions. Why not use the AES code from here www.hoozi.com/post/829n1/advanced-encryption-standard-aes-implementation-in-c-c-with-comments-part-1-encryption
    It says it's C++ but it's plain C really. It's not optimized for speed but that may not be an issue. It also supports 192 and 256 bit keys!
    Terms of use may be an issue, best to ask about that.
    edited 2010-07-12 10:02
    I'd already looked at that. The Microchip code is far more efficient (it's written specifically for their hardware and compiler) and comes with additional stuff like TCP/IP encryption, which might come in useful in the future.
    Leon Heller
    Post Edited (Leon) : 7/12/2010 10:08:24 AM GMT
    edited 2010-07-12 11:50
    Hi Leon,
    no, I'm a close neighbour, Ireland. Seems good so far. How do you see the system working?
    A) Would the prop read the encrypted data in blocks, send it to the PIC and then read it back from the PIC?
    Or
    B) Would the PIC read the data directly from the SD card and transmit the plain text to the prop?
    I would prefer the first method, as we could design a small addon board with the PIC chip and any required components on it. I have a 6 way connector with +5V, +3.3v, Gnd and three I/O pins (non consecutive).
    Please bear in mind that my knowledge of encryption is next to zero.
    !) What else would be involved in implementing the full system, that is the software for the PC to encrypt using a public key?
    2) Also can the PIC securely store a secret key that I can set and possibly change but nobody else can access?
    edited 2010-07-12 13:26
    I think it can be done either way, the first should be OK. I'd suggest SPI for comms between the two chips, as the PIC has an SPI port, and it's nice and fast.
    I've only been involved with encryption techniques once, when I worked for Racal Comms. We were using the then new MoD crypto, Pritchel, in a new radio system, and I was quite heavily involved with it, but it was a long time ago and I've forgotten everything about it.
    Key distribution is something we'll have to look into.
    The PIC can easily store a secret key. The only problem is that 16-bit PICs don't have on-chip EEPROM, so it will have to be held in an external EEPROM, which might compromise security. If it doesn't change very often it could be held in flash. I could use a different PIC with on-chip EEPROM, of course.
    It might be a good idea to take this off the forum, and communicate directly. You can get my email address from my profile.
    Leon Heller
    Post Edited (Leon) : 7/12/2010 1:35:36 PM GMT
    edited 2010-07-12 14:53
    Off chip EEPROM for keys means you might as well just use the Propeller.
    Holding keys in flash perhaps if the thing can be re-flashed whilst at the same time preventing others from reading the FLASH.
    I'm guessing this is for a dongle, right?
