Prop Educ Kit: drawing too much current?
I've got the 40 pin DIP Version of the Propeller Eduction Kit.
I'm able to run the PING sensor, an LCD (with backlighting) and a GPS (all from Parallax) individually. They are all 5 volts and powered from the 5 volt supply on the kit board.
But I can't run them at the same time. If I have the ping and the LCD running and plug in the GPS things go bad.
Am I drawing too much current? What alternatives do I have?
Thanks!
Tim Zajic
Thanks!
Tim Zajic
If you have a 6-12 volt wall wart you could use that as a power supply or you could use a battery pack, such as 4 AA cells. I use either a five cell NiMH battery pack or a wall wart.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
It motivated me finally get a real power supply running. Couldn't be happier.
John
Also, is there a way to determine how much load a 9-volt can take before performance is impacted?
Thanks all!
Tim
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/lm2940/List/0/SortField/4/ProductID/242/Default.aspx
The kit came with a .47 uF capacitor that needs to be put across the terminals, as described on Page 30 of the PEK Lab Book.
Good luck,
John
I use a 6 V, 1000 mA wall supply with a little adapter that has a 9 V battery output terminal. A 6 or 7.5 V regulator output with a high current rating (1000 mA or more) is important. Rechargeable hobby battery packs in the 6 to 8 V range are also good.
Higher supply voltages reduce the regulator's current output capability because the regulator is limited by how hot it can get, and it generates more heat with higher input voltages. A heat sink will definitely help. Another alternative is to build a second 5 V regulator to supply certain power-hungry 5 V parts. The regulators could share the same supply, or each one could draw from a separate supply. Just make sure the grounds·are common (negative terminals tied together) for all supplies and regulators.
Andy
P.S. Radio Shack doesn't carry my little 9 V battery adapter any more. If anybody has a pointer to a good adapter, please do share. Thanks.
Andy Lindsay
Education Department
Andy's adapter gave me an idea. a 9V battery clip spliced to a banana plug cable used by the supply would make it even more convenient. And the banana plug cables also stack, so you could easily connect additional devices, up to 2 amps. What a deal.
John
