Accessing a byte within an array of longs. — Parallax Forums
W9GFOW9GFO Posts: 4,010
edited 2010-06-20 05:51 in Propeller 1
I know you can access a particular byte within a long like this: MyVar.byte[noparse][[/noparse] 2]
How can you address a byte within a long that is part of an array?
VAR long MyVar[noparse][[/noparse]100]
MyVar[noparse][[/noparse]23].byte[noparse][[/noparse] 2] does not work.
Also, how can I look at just one bit in an array of longs?
Rich h
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 6/20/2010 12:14:46 AM GMT
    edited 2010-06-20 00:05
    You can do it the verbose way: byte[noparse][[/noparse] @myvar[noparse][[/noparse] 100 ] ]
  • T ChapT Chap Posts: 4,224
    edited 2010-06-20 00:09
    I think you may have lost some of your intended code due to formatting in the forum, since you would need to specify which byte by using byte[noparse][[/noparse] 3 ] for example. I can't get this to work MyVar[noparse][[/noparse] 23 ].byte but this does: MyVar.byte[noparse][[/noparse] 10 ] for example, where you would have to manage in multiples of 4 which long/byte you want to access.
    edited 2010-06-20 00:23
    byte[noparse][[/noparse]­@MyVar[noparse][[/noparse]­23]][noparse][[/noparse]­2] is probably the most intuitive.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-06-20 00:24
    Todd Chapman said...
    Original post edited to add a space inside the brackets.
    So does MyVar.byte[noparse][[/noparse]23] point to the 24th byte in the array which is byte 3 of MyVar[noparse][[/noparse] 6]?
    Rich H
    edited 2010-06-20 00:31
    The verbose way it is! Thanks.
    Now, is there an equally simple way to look at a single bit within an array?
    Rich H
    edited 2010-06-20 03:39
    W9FGO,·you could try something like this,
    if (byte[noparse]/noparse]@myvar[noparse][[/noparse]23[noparse][[/noparse]2] >> 4) & 1
    · 'this bit is a 1
    else
    · 'this bit is a 0
    The 4 in the if statement above is the bit position(0 - 7)·you pick to check. But I'm not a expert so maybe one of the gurus here can step in and show us a better way!
    edit: thats looking at bit position 4(0-7) of the 3rd byte of the 24th long in myvar[noparse]/noparse
    ···································Fix it, if ain't broke!
    D Rat
    Dave Ratcliff N6YEE
    Post Edited (ratronic) : 6/20/2010 3:51:34 AM GMT
    edited 2010-06-20 04:43
    I was thinking of something like this;
    if myvar[noparse][[/noparse]23] & $10_00_00_00 '(%00010000_00000000_00000000_00000000)
    'bit 4 of byte 3 of the 24th long in the array is a 1
    else
    'bit 4 of byte 3 of the 24th long in the array is a 0
    Or a maybe this is simpler;
    if myvar[noparse][[/noparse]23] >> 28 & 1
    Rich H
    edited 2010-06-20 04:51
    The quickest to execute would probably be this: if myvar[noparse][[/noparse]­23] & constant(1 << 28)
    It saves having to do the shift at run-time.
    edited 2010-06-20 05:07
    Yes if your looking at a long instead a byte then it would be,
    if (myvar[noparse][[/noparse]23] >> 28) & 1·
    the >> 28 gets the bit you want shifted to bit position 0·, the & 1 masks out any other bits than bit position 0. With a long, bit positions are 0 - 31 (32 bits). Also notice where the parenthesis are placed
    Edit: = thanks Phil, I was hoping somebody would show a better way!
    D Rat
    Dave Ratcliff N6YEE
    edited 2010-06-20 05:22
    If the bit has any significance beyond a purely mathematical one, it's better for readability to give it a name and test if that way:
    CON
    GLAXORBIT = 1 << 28
    if (myvar[noparse][[/noparse]*28] & GLAXORBIT)
    Plus, if you decide GLAXORBIT needs to be located somewhere else, you've got only the CON statement to change.
    Would this work?
    CON
      randomByte = $FF << 5     ' arbitrary group of 8 bits   (00000000_00000000_00011111_11100000)
    VAR
      long myVar[noparse][[/noparse]100]
      byte myByte
    PUB Main
      myVar[noparse][[/noparse]23] := $FFFFFFFF
      myByte := GetByte(myVar[noparse][[/noparse]23], randomByte)
    PUB GetByte (_var, thisByte)
    result := _var & thisByte >> ((>| thisByte) - 8)
    Rich H
    Post Edited (W9GFO) : 6/20/2010 6:22:32 AM GMT
