How to specify counter module A or B in SquareWave.spin - newbie question
I am new to Spin and would appreciate assistance in how to specify a particular counter module A or B in the public Object SquareWave.spin (below). Thank you!
PUB Freq(Module, Pin, Frequency) | s, d, ctr
'' Determine CTR settings for synthesis of 0..128 MHz in 1 Hz steps
'' in: Pin = pin to output frequency on
'' Freq = actual Hz to synthesize
'' out: ctr and frq hold ctra/ctrb and frqa/frqb values
'' Uses NCO mode %00100 for 0..499_999 Hz
'' Uses PLL mode %00010 for 500_000..128_000_000 Hz
Frequency := Frequency #> 0 <# 128_000_000 'limit frequency range
if Frequency < 500_000 'if 0 to 499_999 Hz,
ctr := constant(%00100 << 26) '..set NCO mode
s := 1 '..shift = 1
else 'if 500_000 to 128_000_000 Hz,
ctr := constant(%00010 << 26) '..set PLL mode
d := >|((Frequency - 1) / 1_000_000) 'determine PLLDIV
s := 4 - d 'determine shift
ctr |= d << 23 'set PLLDIV
spr[noparse][[/noparse]10 + module] := fraction(Frequency, CLKFREQ, s) 'Compute frqa/frqb value
ctr |= Pin 'set PINA to complete ctra/ctrb value
spr[noparse][[/noparse]8 + module] := ctr
dira[noparse][[/noparse]pin]~~
PUB NcoFrqReg(frequency) : frqReg
Returns frqReg = frequency
s := 1 '..shift = 1
In advance, thank you
SPR is an array covering the special registers (SPR[noparse][[/noparse]0..15] ~ $1F0..$1FF). Meaning SPR[noparse][[/noparse]10] is $1FA == frqa and SPR[noparse][[/noparse]8] is $1F8 == ctra. Using module as an offset gives you frqb/ctrb.
This object looks awfully similar to Synth.spin as part of the PropellerTool library. Synth.spin should be easier to understand.
