Transistors: how to know which one is the right one?
Hello,
Getting into the mystery of transistors!
How can I know if a certain transistor can allow certain voltage/mA's to go thru it?
For example, with the BS2 start set I got a transistor that reads
2N
3904
-338
...which means nothing! How can I know whether I can apply, for example, 5 volts to it's input and connect a 50 mA diode or a light bulb to it's output?
How do I know when I need to combine the transistor with a relay switch, and when I can use only the transistor without relay for such application?
Thanks!
2N
3904
-338
Thanks!
http://www.fairchildsemi.com/ds/2N/2N3904.pdf
How do I read what I need from all this?
2) Read the datasheet. If the transistor can handle the amount of current and voltage you need, then you probably don't need a relay. Relays have the advantage that they have isolation between the coil and the contacts. Sometimes you need that. Read the Wikipedia article on relays.
Absolute maximum ratings are the most important. If you exceed them, you may break the device.
Power dissipation tells you how much heat it can get rid of which depends on how much heat you generate. You need to learn about basic electronics otherwise this is just another fact you'll forget or won't make much sense of.
DC current gain (hFE) gives you a rough idea of how much current the transistor will control given how much current is input to it. Read the Wikipedia article on transistors and the links from that. Again, this is basic electronics.
Post Edited (Mike Green) : 6/17/2010 4:15:38 AM GMT
In particular:
Can I connect a 50 mA diode rated at 3V by connecting P0 to the transistor's "switch" pin; and connecting the Diode to Vdd and a resistor through the transistor?
Is it correct to assume on my side that this data sheet tells me this transistor works on 6V for the "switch" pin; and can process 60 volts at 200 mA max over the two other pins?
Casey
I fish, therefore I lie!
Is this good, or is it always better to have a diode that will prevent electricity going back from the Base into the IO pin?
- Stephen
If you mention something that's in a manual, it would be helpful to mention the page number or the figure number or the example number. What you're asking makes no sense without some context.
You're asking a lot of questions and the questions themselves are not asked well. The way to get the best help in these forums is to:
1) Make them as specific as possible.
2) Give some context including a description of what you're trying to accomplish
How is a transistor made? How does it work? What's the equivalent circuit (if it were made of simpler parts put together)? Read the Wikipedia article or maybe a chapter on transistors on a basic electronics text.
