Mach 3 cnc controller communication
Hello all,
While I'm not new to coding, I am new to the basic stamp and its syntax. I have a BS2 v1.0, using editor 2.5.
Mach 3 is CNC controller software that allows some VB scripting.
I have simple Mach3 vbscript that sends some data:
Then, I have this bs2 code, watching for incoming data:
Like I said, I'm new to the bs2 syntax, so I'm sure the -48 isn't the best solution, but it does work. I've done some testing, and sending 0, 1, 2, 3, etc. will trigger the corresponding pin on the bs2.
The problem is, it seems like each time the code receives any data at all, it resets the stamp. The reason I say this is, I have an LED attached to pin 0. if I send the stamp data "0" once, the light comes on, but when I send it again, it just blinks, instead of turning off like you'd expect with the toggle command. I don't understand why I'm seeing this behavior.
Thanks [noparse]:)[/noparse]
Post Edited (Zaaephod) : 6/16/2010 1:58:56 PM GMT
call sendserial(0)
' {$STAMP BS2} ' {$PBASIC 2.5} sData VAR Byte insignal VAR Byte DO SERIN 16, $4054, [noparse][[/noparse]sData] ' 4800 baud insignal = sData -48 ' the incoming data is a character decimal value, so -48 to get the true number (not the best way, I'm sure) TOGGLE insignal LOOP STOP
You need to make sure that signal stays in the correct state (low I think) otherwise it will reset the stamp.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
When you said that, the first thing I did was to run over and test the stamp code by sending data from hyperterminal, and it works perfectly. LED on, LED off.
Unfortunately, the Mach3 documentation really doesn't give any details about how to use the sendserial function, it seems to be something that was put in, but most people have never used it. Unless this can somehow be remedied by adding character codes or something to the incoming command, or the DTR reset can somehow be disabled in the stamp, I may have just hit a game breaking wall.
Z
Thanks for the info, Bean, that's what I needed to know to fix the problem.
