Prop/RJ 45 question
·Is it possible to use a RJ 45 jack with an ethernet cable to send a signal from the prop to lite up an LED on the other side of the cable? Would any additional hardware be required or can I just·do·this directly from the prop?
Thank you,
CameronM
Thank you,
CameronM
Here is the·link to the RJ 45 Ethernet magjack.
http://www.sparkfun.com/commerce/product_info.php?products_id=8534
Thank you,
CameronM
http://www.sparkfun.com/commerce/product_info.php?products_id=643
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
