Connection wires for MSR1
http://www.parallax.com/Store/Components/WireConnection/tabid/151/CategoryID/29/List/0/SortField/0/Level/a/ProductID/609/Default.aspx
I know parallax has these but does anyone know where I can get single cables of these?
or where I can buy the ends to make my own?
I am interfacing the taos 230 color sensor, and discountinued emic with the msr1.
thanks!
thanks!
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM8019-ND
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM2580CT-ND
or this one
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM2802-ND
Post Edited (Zap-o) : 6/15/2010 1:12:44 PM GMT
Leon Heller
Amateur radio callsign: G1HSM
I need to make quite a few of them. I need like 20.
But I dont need them with 3 or 2 connectors I need single ones.
do you have any links for those? and a link to the tool? Im not quite sure what to search for.
thanks!
www.servocity.com/html/servo_connectors___pins.html
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 6/15/2010 7:08:26 PM GMT
http://cgi.ebay.com/Solderless-Breadboard-Jumper-Cable-Wire-24female-female-/390112801789?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item5ad488f3fd
http://cgi.ebay.com/Solderless-Breadboard-Jumpers-Wires-Female-Female-QTY30-/250583505834?cmd=ViewItem&pt=Vintage_Electronics_R2&hash=item3a57f0dbaa
http://www.parallax.com/Store/Components/WireConnection/tabid/151/CategoryID/29/List/0/SortField/0/Level/a/ProductID/383/Default.aspx
It's really no worth buying a $50.00 tool and sourcing the connectors just to make 20 cables.
Jim
That's a good price on the crimp tool. Too bad it's out of stock. The male pins pictured sure look like female pins, ( I went to biology class [noparse]:)[/noparse] But the OP wants single connectors. The pins will work fine with some heat shrink on them. No need for plastic enclosure.
Jim
Id rather give my money to parallax, but will those plug into the msr1, ping sensors? They seem kind of big, but I dont know if its just the picture.
EDIT:
nvm they look good.
Post Edited (p00ndawg) : 6/15/2010 7:15:27 PM GMT
Parallax has Male-to-Female cables also:
http://www.parallax.com/Store/Components/WireConnection/tabid/151/CategoryID/29/List/0/SortField/0/catpageindex/2/Level/a/ProductID/403/Default.aspx
What are you trying to connect or extend?
Jim
Rich H
this:
http://www.taosinc.com/getfile.aspx?type=press&file=tcs230lensmodule.pdf
and this:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/emic/List/0/SortField/4/ProductID/108/Default.aspx
so i think I need female to female connectors.
w9gfo:
I can just cut them down the middle?
i dont think I have anything sharp enough to cut those servo cables, they're really small.
Post Edited (p00ndawg) : 6/15/2010 7:36:47 PM GMT
Not sure what you mean about the servo cables being too small to cut. If you don't have the "proper" tools, fingernail clippers will work well for small wires, if you're gentle you can strip with them too.
Rich H
