Did I break it...?
While trying to configure a push-button circuit, I noticed I couldn't get the button to pass a voltage. Rather, it always did, even when it wasn't pressed.
I later found out the pins 15 and 14 set as inputs on my stamp were always receiving high, even when disconnected, and wiggling nearby components made them behave erratically (rapidly alternating reception of high and low signals). I suspect that Vin may have been accidentally connected to pin 15 while building a circuit, causing damage to the stamp. I'm not sure, however, if 6V rather than 5V in an input would be enough to do this. All other pins work as normal. It seems broken enough regardless, though. Will I need a replacement stamp? (BS2)
