Professional Development Board and SX Chip.
Hey guys, I just recently bought the PBD. I'm a little frustrated with how hard it it to remove and insert the BS2 ( I even broke a pin in the module but was able to fix it). I was told that the SX Chips which this supports are easier to remove ( I want to program stuff and then insert the microcontroller into a breadboard, this is why I'm interested in removing modules and what not).
Well, my point is, I bought this one
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=162931&catalogId=10001&langId=-1&krypto=HjuFvYrhkyT8LvTOaizTkNRtFfMmArDh&ddkey=http:StoreCatalogDrillDownView
Can I program and use the SX Chip without having to remove the BS2 Module? The I/O Pins are the "R" labeled ones right? Also is there any sort of manual or anything about integrating the SX Chips to this board?
http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/28138-PDB-v2.0.pdf
http://www.parallax.com/Portals/0/Downloads/docs/prod/schem/PDB-RevD-Schematic.pdf
Jim
- Stephen
I recently bought the PDB and had to remove the 2p40 once and yes its not something I want to do regularly.
I have a suggestion, if you have anotther circuit that you are swapping the SX chip in and out, why not simply enable that circuit with a serial interface to the SX programming pins. I really don't know the SX chip,but it should be only 3 maybe 4 wires and a d-sub connector.
See my post from yesterday "Code for bs2p40 w/DS1307 timestamp clock w/user control". Its a fairly complex program with a simple set up on the PDB. But honestly, learning someone elses code can sometiimes be as complicated as writing your own.
Semper fi
http://www.parallax.com/Store/Microcontrollers/BASICStampProgrammingKits/tabid/136/CategoryID/11/List/0/SortField/0/Level/a/ProductID/329/Default.aspx
Jim
and NewBee, lol..also I felt really stupid when I removed it, won't touch that fragile thing again lol
I don't understand.
Jim
·http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/70002/List/1/ProductID/356/Default.aspx?SortField=ProductName%2cProductName
Jim
