Why do wiring differences exist in the Prop Demo Board PS/2 connector vs. the P
I noticed there's a difference in how the PS/2 wiring is done on the Prop Demo Board vs. the PS/2 Breadboard Adapter (Parallax # 28060).
On the Breadboard Adapter, +5 volts is used to "power" the mouse. But on the Prop Demo Board, it shows a +5 connection going to one of the PS/2 pins but then there are also connections made to Vdd, which I presume should be +3.3 volts on the Demo board. Why is there a difference?
www.parallax.com/Portals/0/Downloads/docs/prod/edu/28060-PS2Adapter-v1.0.pdf
www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropDemoDschem.pdf
Mark
Watching the world pass me by, one photon at a time.
Mark
Paul Baker
So does that mean if I design my own pcb, I can use only 3.3 volts if I want to? and not bother applying +5 volts to that other pin of the PS/2? If so, that would really help simplify my pcb design.
Thanks, Paul
Paul Baker
Okay. That's good to know.
Thanks again! Much appreciated!
