LiPoly or coin cell power for 3.3V MCU?
Hi-
I'm looking for a hypothetical board-mount power solution for a very small, low power MCU. I was looking at either a single LiPoly cell or a small stack of (rechargeable?) coin cells.
If I'm running a 3.3V micro, is an LDO reg good enough? As far as I know LiPoly's can go down to 3.0V. If that's the case, is there a better way to power something like this?
Rafael
UC Berkeley '12 EECS
CalSol: UC Berkeley Solar Car
http://calsol.berkeley.edu
KJ6AWU
Rafael
KJ6AWU
In " float " use off a PSU rail a simple well sized Resistor could be used with the NiCd cells //It the charge rate is less then C/30..
In a ideal world a "Simple switcher " would be a more Efficaint choise . and cause your useing super tiny Coin cells you dont have much extra Power to waist as heat ..
I have seen Drop In LM78XX equliviaint Switchers .I forget the company name but there In Nuts and Volts
In Gnd Out Simple little things ...
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
R
KJ6AWU
Peter KG6LSE
LOL
Xbee power average can be low, but expect 40 mA while receiving or up to 200 mA when transmitting.
A low dropout regulator is probably best, as the efficiency of turning 3.7V into 3.3 is about the same as a switcher. What a switcher could do is to provide 3.3V as the battery discharges below 3.3V. But this probably isn't needed as things like Xbee will run at lower than 3.3V. But in any case your circuit should be sending out "come charge me" messages at that point.
