Why use a prop? — Parallax Forums
Why use a prop?
mwalimumwalimu Posts: 44
edited 2010-06-18 05:41 in Propeller 1
I have been working on a propeller controller for a Roomba. While I was digging through some stuff I found a evaluation board for a a Cypress PSoC chip. It's got a 29466 chip(roughly equivalent to an ATMEGA328). I realized that I could easilly use that instead of the Propeller, in fact, the PSoc has several advantages, it has on board ADC, DAC, PWM, etc, all of which can be configured by the user in a variety of different ways.
It got me to thinking (not always a good thing). For the most part the cogs on the Prop is being used to create peripherals that are generally available on other chips, so why use it over another chip?
What projects are best suited for parallel processing?
(sorry, I left out the subject)
    edited 2010-06-14 04:17
    mwalimu said...
    1. The cogs on the Prop can also be used to create peripherals that are not generally available on other chips.
    2. Any soft peripheral can be assigned to any pin or pin group. (Try that with an Atmel chip.)
    3.There are way fewer special function registers to learn with a Prop, so development turnaround is much quicker. (Would you call the PSoC chip a "rapid dev solution"?)
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-06-14 04:45
    Speaking in examples:
    try to find a chip that has 12 serial interfaces plus a TV output.
    Easy to do with the propeller.
    And yes, what PhiPi says about the special function registers, the interface pinout and rapid prototyping are from my point of view the killer arguments. You don't have to waste a second for thinking about which interface needs to be connected to which pins. This makes the PCB design job much easier. SFR's are really a pain and one bit set wrong can cause hours of debugging. Interrupt programming is also a pain and building failsafe systems needs a lot of experience. The more hardware resources are used, the more complex the interrupt programming will be.
    So, very easy things can be done with other uC as easy as with the propeller, but the more complex the system is, the more advantages are on the propeller side.
  • KyeKye Posts: 2,200
    edited 2010-06-14 05:02
    Why use a prop... Mmm.
    Alot of people ask me this. I really can't say why they should use one if they are comfortable with something else.
    As long as they don't ask me for help when they aren't able to finish a project with the micro of their choice I have no problem.
    Otherwise, they should use a prop.
    Nyamekye,
  • bill190bill190 Posts: 769
    edited 2010-06-14 05:34
    I really like the idea that separate cogs can be assigned full time to a task. Like monitoring for button input, updating a display, checking sensors, etc.
    Other microcontrollers can only do one thing at a time. The Propeller can do several different things all at the same time!
    I eventually want to put in a solar water heating system. I will want to monitor the roof water temperature, the water tank temperature, activate a pump, have a display, and have button(s) to press for this and that. I think the Propeller would be ideal for something like that.
    With another microcontroller, it would be too busy doing other stuff to check for a button press. Or I would need to use interrupts and an interrupt handler.
    I would think I could more quickly get my system up and running with a Propeller. Much easier! And much easier to add say a new display later on or additional buttons to display something.
    Also the propeller is·more "modular". If I wanted to add a remote display, I could work on that one feature with another Propeller. Then easily add that object to the working system. With other microcontrollers, adding something like I2C (or whatever) and changing configuration bits/interrupts could cause other things to stop working.
    For example I·just downloaded·a C serial program for a Pic which uses the memory space allocated for the USB.
    edited 2010-06-14 06:25
    Oh ... another reason:
    Development of systems that have to communicate to each other. For example using an RF module. With a propeller you only need one prop, using 2 different COGs for implementing the protocol and it's so easy to verify that what you send with one COG equals what you receive with the other. When you're done with the protocol you can run the same object in 2 different propellers which makes no difference.
    Now try that with another uC. Even if you can handle 2 RF modules you have to use interrupts. This means when you then put the protocol code into the target systems it can behave very different. So, if you really want to make sure that it all works out you need 2 development boards.
  • heaterheater Posts: 3,370
    edited 2010-06-14 07:04
    Don't forget it's not just the Prop chip. It's the whole environment and, well, philosophy. Everything has been designed from the silicon up to be as easy to use as possible.
    The Propeller architecture makes for very easy program building with its multi-cores and therefore interrupt free programming with total timing determinism. This makes adding new little features or adopting modules from others extremely quick and easy to do. You don't have to constantly worry that consuming a little time with the next new feature will break you whole app or make you code into a fragile mess.
    This Spin language is very easy to pick up and the Propeller Tool very easy to use.
    When you need speed the Propeller assembly language PASM is about the simplest I have ever come across. It's direct integration into Spin programs is a doddle.
    Then there is the OBEX, a wonderful playground of ready made programs, objexts device drivers.
    Features like video generation, audio/analog I/O are the icing on the cake.
    Now, a lot of this may not matter so much if you are building a million embedded devices for a minimal parts cost but it's perfect in educational/hobby settings. It's perfect for a huge world of applications where a quick prototype or development is required.
    Don't forget if you depend on built in peripherals of normal micros you will quite likely end up having to select a new chip for each application. Keep stocks of different variants of the same micro. Get your head around the capabilities/limitations of each one.
    With the Prop you can keep a bin full of them. They are a general purpose "blank slate" that can be adopted for many varied applications.
    I don't think you will find another micro-controller forum with such a quick and helpful turn around as this one. That comes from the enthusiasm of the Propeller users which I believe comes from that "philosophy" I opened with.
    edited 2010-06-14 07:06
    It's true that some cogs will be used to create the peripheral blocks that exist in other micros. So you decide what blocks you require in another micro and then look at the different versions to find one that has the complement you require. You then buy it and lay out a pcb for it. Now you decide you require an extra serial port (or some other peripheral not in the version you have chosen). Now back to choose another version and of course a new layout as the pinout is different. With a prop (currently there is only 1 version), you just add it in software and a minor mod to the pcb and you are running.
    However, cogs are also useful for doing other things at the same time. Don't forget the props speed. Don't forget you have 32KB of hub sram as well as the cog sram plus usable sections of code in hub ROM. And you have a high level language (spin) for when speed is not required which is typically the main loop of a program.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
  • ErNaErNa Posts: 1,856
    edited 2010-06-14 07:36
    Why use a man to hunt an antelope, when a tiger can do it better?
    cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
    Hello Rest Of The World
    Hello Debris
  • smbakersmbaker Posts: 164
    edited 2010-06-14 07:39
    For me, the decision comes down to programming paradigm. Let's say we have an average embedded controller application - there are several things going on in parallel. You might need to constantly refresh a display, check for keyboard input, do computation, update a state machine, stream data to or from SD storage, play a sound effect, etc. If you want to write something like that using a typical microcontroller then you either try to do some kind of event programming, or interrupt-driven programming, or some nasty big loop that multiplexes all of these tasks. It can be difficult to guarantee performance on one task while it's being interrupted by other tasks. Alternatively, some microcontrollers come with a real-time OS that might let you multitask using a threaded model.
    With the prop, you put each one of your tasks in a separate cog. You can get guaranteed performance from a cog and you don't worry about an interrupt or a context switch impacting behavior on a time-critical task. In this way I think the prop has the potential for much more robust and predictable behavior than a single-core device.
    As an example, I developed an internet-enabled alarm clock. It updates a LED display, outputs to TV, streams audio from SD to speaker for custom alarm tone, processes keyboard events, and continually updates itself via NTP over ethernet. All of these tasks in different cogs. All of these tasks running concurrently without interfering with each other.
    The OP is right that more peripherals might be handy, such as ADC or serial or usb. Maybe the prop II will give us some of that.
    edited 2010-06-14 08:22
    It is the paradigm. Real things are running in parallel and there is a natural way to synchronize activities. As we start to teach we need a curriculum to bring out the joy from the process of learning ;-( The propeller allows you to solve a problem the "natural" way. Analyze the structure of the problem, divide it into manageable parts, implement a communication structure and don't care about interrupts. The first goal of the propeller is, from my point of view, to give a new insight into how to solve complex problems. It's pure fun! Particularly if you went the way through the history of microcontrollers.
    Hello Debris
    edited 2010-06-14 08:50
    Because one 32 bit 20MIPs processor is good. Eight of them working together as in the Prop is more than 8 times better. And certainly better that one normal 32 bit processor at 160Mips.
    Shame it does not go to 11 [noparse]:)[/noparse]
  • jazzedjazzed Posts: 11,803
    edited 2010-06-14 16:25
    You can blink LEDs with any micro-controller or by other means.
    People here have done amazing things with Propeller that are impossible with comparable AVRs. We all do what we like when we can. If you like AVR or PIC and certain software development paradigms, do that. If you want to get indefinitely hooked and don't mind a little eccentricity, do Propeller [noparse]:)[/noparse]
    Cheers.
    --Steve
    Propeller Pages: Propeller JVM
  • GranzGranz Posts: 179
    edited 2010-06-14 19:46
    Phil Pilgrim (PhiPi) said...
    mwalimu said...
    I have to reiterate PhiPi's number four - this forum, and the UPEs are the main reason that I have purchased so much Propeller stuff. Yeah, the Prop itself is a pretty impressive chip and all, but the people who are into it are pretty much the biggest selling point to me. When you get together with other people interested in something, it is easy to get/stay interested in that thing (whether they get together on a very active forum like this, or in person at something like the Unofficial Propeller Expos.) Most of my business is related to the Atmel families, and so a lot of my effort goes into that, but I have never seen anything like the Prop Expos in any other modern chips. AVR Freaks is nice, but they are not quite as active and they are spread out more than the Propheads, and I've never seen anything like our Expos in the AVR areas. There is something infectious about getting together with an excited crowd, and so the Prop and other Parallax things are moving, more and more, into my development plans
    Art
    edited 2010-06-14 20:15
    I'm working on a short program for an ATtiny88 right now.
    Using the 8mhz built in oscillator to save the cost of an xtal.
    I need something done 20,000 times a second...So I'm using
    timer 1 ... ISR(TIMER1_COMPA_vect) and I have an absolute
    maximum time of 400 cycles inside the timer1 interrupt routine
    and if I even get close to that maximum all #$%^ will cut loose.
    So the ISR is getting coded in assembler, the rest is in C.
    I have 3 interrupt routines going at once...it's messy in there!
    And everything jitters a bit.
    I'd rather be using a prop! If it wasn't for the price difference I
    would be. (1.40 vs 7.19 in quantity 100)
    I can't imagine using something else as long as a prop is price
    competitive.
    If there was a 2.00 2 cog prop I'd be using it right now instead
    of this cranky tiny88.
    edited 2010-06-14 21:02
    I find the absence of interrupts very cool. I do a lot of stuff with servos & remote control inputs, which require sub-microsecond accuracy when setting / reading the pins. On a chip with interrupts, if you're in the middle of your servo output routine and you get an interrupt on a remote control input line, you have to decide which value you can afford to sacrifice accuracy on.
    On a Prop, I have no such problems. My current flying thing uses 5 cogs:
    1) Remote input
    2) Servo output
    3) Gyro / Accelerometer I2C input / IMU
    4) Serial output (debugging)
    5) Main flight loop
    Doing the same thing on a single-threaded piece of hardware is remarkably convoluted and awkward. I've done it, but it's painful, even on a chip with dedicated I2C, serial, PWM, and pulse timers.
    Jason
  • tonyp12tonyp12 Posts: 1,951
    edited 2010-06-14 21:25
    Unless you are mass-producing· a product and the mcu have to cost less·than a $1 to meet budget.
    Go with the Propeller.
    I'm learning to use the freescales RS08,
    hard to get started·with codewarrior compared how·easy·PropTool is.
    Only 150 bytes of ram available at anytime, have to use a page window·for each 64bytes
    Freescaled 8bit online forum is one boring place.
    Post Edited (tonyp12) : 6/14/2010 9:43:50 PM GMT
  • Sal AmmoniacSal Ammoniac Posts: 213
    edited 2010-06-14 22:26
    I try to use the Propeller for everything except applications that require either lots of code space or lots of floating point math. These two areas are probably the only two weaknesses of the Propeller.
    I find the Propeller paradigm and development model to be straightforward, easy to use, and, not least, fun! As others have already mentioned in this thread, the special function registers used by other MCUs to control their on-chip peripherals seem absolutely convoluted, messy, and easy to screw something up with minor errors than the I/O model on the Propeller. After reading 1200 page data sheets on other MCUs, 900 pages of which are dedicated to the peripherals, the Propeller's simple dira and ina/outa registers are refreshing.
  • mikedivmikediv Posts: 825
    edited 2010-06-14 23:02
    If your just asking in general ,, fo rme its the ability to do video out with virtualy no other support chips just 3 resistors is pretty amazing I also find the Obex to be a real nice support feature I can not count how many programs I have been using from there,, also the serial is pretty easy and· the ram/eprom interface is a snap I can build a whole working board prop,ram,eprom, serial interface, video interface color to boot. then add whatever sensors and go to the obex find some code that will support them and tweak it and Wola a nice little MCU control board, robot brain whatever. I also use the basic stamp and now Atmel Tiny MCU's as well as Arm stuff but if someone came to me asked for a desgin for me to build
    for some type of control or data aqusistion or as of late a self contained and auto functioning random target· system for pellet gun shooting its the prop .. It just helps me· be a better designer I can honestly say with all the PICs and other MCU's or even CPU's I know of nothing with the power and ease of use as the prop .. Oh and not to give anyone a big head or bigger head lets not forget this fourm plain and simple have you ever found a better place for support regardless of the chip?? Just taking that into consideration its very nice to be able to come here and say hey guys can anyone help me with X I am on lots of other sites and have meet some nice people but nothing at this level
    Post Edited (mikediv) : 6/14/2010 11:08:26 PM GMT
  • mwalimumwalimu Posts: 44
    edited 2010-06-15 22:37
    Thank you for your answers. I think I need to rephrase the question. I agree that the Propeller is a wonderful chip and that Parallax has provided superlative tools and support. I'm more interested in exploring what kinds of tasks lend themselves to parallel processing. I agree that making peripherals out of cogs is nice, but most chips you would use have the basic devices,UARTS, SPI, I2C,etc. and not all of them are interrupt drive.
    For the most part when I look at projects done on the prop it seems that cogs are used to implement devices and one cog is used to drive the computing part of the project. That doesn't seem to me to be an improvement over a well designed single core chip.
    For what tasks is parallel processing a good solution?
    edited 2010-06-15 23:40
    Parallel processing is a good solution whenever you have several relatively independent tasks to perform. Making software peripherals is one situation where you have a fairly independent task to perform. Doing floating point where the operations can be queued up and some can be done in parallel with some other task not involving floating point is another situation. The advantage for having multiple independent processors is that you can dispense with a lot of the scheduling and "time-sharing" mechanisms normally used to simulate having multiple processors (like interrupts) as opposed to actually having multiple processors. By having multiple processors, you can often devote a processor to a task very much simplifying the task even though the processor is idle much of the time.
  • K2K2 Posts: 695
    edited 2010-06-15 23:41
    A whole bunch of really great responses already addressed this question. The real world is parallel. For example, what part of JasonDorie's post didn't you understand?
    The early bird gets the worm but the second mouse gets the cheese.
  • p00ndawgp00ndawg Posts: 70
    edited 2010-06-15 23:50
    I got a robot that roams autonomously, scans 10 pings, scans for rfid's, speaks, and has boundary control with a color sensor.
    the prop destroys these tasks.
    edited 2010-06-16 03:20
    "A whole bunch of really great responses already addressed this question. The real world is parallel. For example, what part of JasonDorie's post didn't you understand?"
    No need to be unpleasant. I just wanted some opinions on parallel processing that goes beyond making cool peripherals.
    edited 2010-06-16 05:25
    Seems to me, any solution where there are several discrete tasks has some built in advantages on a Propeller. They can all run independent of one another, as if they were actually several different chips. Modular design in this case isn't difficult. A simple launcher is needed, and some memory and pin planning, but beyond that, each task just does it's own thing. Debugging is a much smaller scope problem in that scenario, as each task can be isolated, without any real hassle.
    On a non-parallel system, there are always interactions to consider. Code bodies can be written so that there are few to no interactions, acting like a prop, but that's a skill and time burden not present on a prop. And there's a whole testing cycle not present on a propeller either. This isn't a small task, and the sale of libraries designed that way is done for that reason. On a prop, objects can be combined in a lot of ways, with only modest planning being required.
    Robust solutions could be done with tasks operating in parallel, doing the same thing. If one fails, the solution remains viable.
    The ability for the chip to actually output what another part of the chip is doing is damn cool. I've done a little of that, using one COG to tell me what the code on another one is doing with the pins.
    What about cases where a given signal input requires that a lot of things happen at once? Several COGs, each waiting to perform a task, could all begin that task at the time of detection.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    Safety Tip: Life is as good as YOU think it is!
  • K2K2 Posts: 695
    edited 2010-06-16 06:03
    "No need to be unpleasant. I just wanted some opinions on parallel processing that goes beyond making cool peripherals."
    I'm not trying to be unpleasant. I'm just saying that when you categorize everything everyone has described as just more "cool peripherals" one wonders if you were paying attention.
    Your original question was "What projects are best suited for parallel processing?" I think this was answered over and over again. The answer is "Most Projects." [noparse];)[/noparse]
    edited 2010-06-16 06:18
    mwalimu said...
    If you'll read the forums, it's easy to conclude that people are using the prop to emulate peripherals because that is what a lot of the posts are about (emulating SID chips, video drivers, etc) and it's where there are some really cool and visible results. However, I don't think that's what the prop is really about. As K2 summed it up in his post, "the real world is parallel". People have lots of varied backgrounds when it comes to programming, so I'm unsure of what you're experiences are, but much of the stuff I do involves several tasks that have to take simultaneously. This is true whether I'm programming a microcontroller, writing a Windows application, or doing Linux kernel work. To serialize several parallel tasks on a single uniprocessor is always an imperfect process because one task always needs to be interrupted by another. If you have multiple cores then you can actually do the parallel tasks in parallel, the way they were meant to be done.
    I find the propeller to be much more about basic design philosophy and much less about what specific peripherals can be implemented.
    edited 2010-06-16 06:52
    mwalimu said...
    Yes indeed and that's a reasonable and natural architecture in a lot of applications.
    mwalimu said...
    Perhaps but which of the well designed single core chips do you want for an app?
    1) The same Prop chip can provide an infinite variety of peripherals (within the performance limits). One does not need a large inventory/knowledge/access to a lot of different versions of the same architecture, ARM, PIC whatever.
    2) Design changes are easier. Want to move that UART to different pins? Easy. Want to swap that serial link for something else? Easy. etc etc etc
    3) What about when you want to drive a "weird" peripheral? I have a project on the back burner to drive a 4 wire communications protocol that would be very hard to do on a regular micro with bit-banging and interrupts. This is an example of "software defined silicon" a term coined by XMOS whose chips offer similar multicore functionality. You can implement logic in software using a few pins that would otherwise have to be done in discrete chips or an FPGA.
    4) Those well designed single core chips may well be fine. But how easy are they to use in practice? Generally you cant just throw another blob of code in there to handle some new functionality and know that it will just run with out disturbing the existing application. Often it requires hooking into the interrupt system or the RTOS being run. Then you have to worry about how that has disturbed the timing of everything else. Or perhaps it requires peripheral blocks or I/O pins you have already assigned to something else.
    mwalimu said...
    Well we are talking "micro-controller" here so anything that need to interface to the real world for status monitoring/control functions. Especially if there are stringent requirements for deterministic timing and there are multiple external activities going on. Like that helicopter you are trying to stabilize.
    The "software defined silicon" idea absolutely requires parallel processing and timing determinism.
    In general you can forget about the Prop for the traditional idea of "parallel processing" i.e. as a way to accelerate number crunching on large sets of data. The "super computer" approach. There are better ways to get that kind of performance and the required communication bandwidth between nodes.
    The Prop is after all a micro-controller.
    edited 2010-06-16 07:38
    mwalimu said...
    We have all been stating how you can use a cog to make a peripheral. So let's look at the simple UART. In the prop, we do not just perform the UART emulation (i.e. the registers). We actually also control the first·level of the interface, which you would have to perform under interrupt in a normal (single cpu) micro. This is done in the FullDuplexSerial (commonly referred to as FDX) object. All the UART registers in reality, do not exist. The FDX handles all this functionality and places received characters into hub memory buffer·without any interruption to the main program. The main program·processes these when it likes.·Likewise, transmit characters are placed into the hub buffer for transmission and the FDX takes them and transmits them. Nothing could be more simpler. But wait, FDX could be extended to also perform a little more complex work on the transmission, such as inserting a CRCC to a block of data, etc. There is a version of FDX which handles 8 UARTs.
    There is another object (Debug_1PinTV) which displays characters on a TV. You just output a character to a hub location and the cog takes the character and places it into the screen buffer. If it is a control character, such as clear screen, carriage return, up/down/left/right (a basic terminal emulation) the cog also performs this. If a scroll is required, it does this also. And, it is also displaying the characters on the TV. By this I mean, it is also reading in the screen buffer and converting the characters to dots using it's inbuilt font and supplying this to the counter logic to form a composite video output to your TV, all with the aid of 1 resistor and 1 prop pin (it is only B&W). Normally, the TV uses 3 pins and 3 resistors to get composite color (NTSC or PAL). So here we not only have the complex TV generation hardware, but also a small terminal emulation as well (VT100 style sub-set), all without the main user program worrying about such things. All without interrupts and registers to worry about controlling.
    Yet another object is the Keyboard object. It interfaces to a standard PS2 PC keyboard using 2 pins and 4 resistors plus 5V for the keyboard. There is also a 1pin version using 3 resistors and 5V. These objects not only provide the hardware interface and the software to communicate with the keyboard (uses an I2C style protocol), it also optionally performs the conversion from the keycodes to ASCII before it places the characters into the hub buffer. So once again, no interupts and no complex registers to control by the main user program.
    So, you can see from these examples, the multiprocessors (cogs)·are used more than just emulating the hardware blocks found in other micros, but they also add a degree of intelligence to these basic blocks so they become "smart peripheral blocks", processing the smarts in parallel to your main code.
    Of course, you can also enlist cogs to do other processing in parallel. That is what Jason is doing in his quadcopter designs. Sure, the same can be done with one of the bigger ATMega cpus (see Sparkfun) but it is much simpler in a prop (for the programmer) to have each block of code processed independently and in parallel. No interrupts to worry about.
    You could use a second·cog to do some complex calculation by storing the values to be used in hub memory and then continue with something else. The second cog would take these values and perform the required calculations and place the results back into hub memory for the main program to use at a later time. This task would be executed in parallel.
    Quite often I have found that the main program now can be written in Spin because it·no longer has to be fast in execution. This of course makes your program easier to follow and hence debug and maintain.
    I hope this helps you understand some of the advantages of the Propeller.
    edited 2010-06-16 07:51
    "For what tasks is parallel processing a good solution?"
    The answer is: every task is originally something parallel. It is serialized artificially to handle the task by a single "processor". Why, for example, does a picture say thousand words? Because perception of a picture goes in parallel, while words, spoken in parallel can not carry more information then the sound of 1000 vuzuelas! Describing a picture is a process of serialization, then, later after reading, the picture can be present in brain as one item, that is, "parallel".
    But as we teach people how to solve problem with serial processors, they do not realize, what the problem was originally, but they see their skills. And as serialization is a problem and needs skills, we are proud to solve those second level problems.
    But Chip pointed us to this: there is a better solution, I give You the tool!
    Hello Debris
    edited 2010-06-16 07:57
    ErNa: Exactly...And what a tool it was !!!
