Is it possible
· Ok, I am nuts, but I was reading that you can make a simple seismograph using just speakers. The idea is that speakers contain a coil and any vibration will cause the speaker to generate a small voltage. In the project I read they said that voltage could be detected by using the pickup on a cassette player read/write heads. My question is. Is there enough voltage there to be detected by a basic stamp? If so any ideas on how to read that voltage?
Thanks In Advance For Any Ideas
I've fooled around with several seismographs. Almost as simple and far more efffective is a super mangnet suspended over a coil, like a coil from a 120VAC relay. You can hang it with string, or better yet some sort of solid bar (wood dowel for example). You can also experiment with dampening using a chunk of aluminum or copper (or any non-ferrous metals). I think you'll have better luck with this method. One siesmograph I made could detect the ocean waves (during a big storm) hitting the beach about 4 miles away.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
This uses a LDT0-0128K Piezo Vib.Detector and a MCP601 amp. This should be pretty easy to integrate to a BS2
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
