Cognew? How to start another cog to do a task for me.
right now i have a loop that does x number of things and writes them to variables.
Now i want some other code to work simultaneously to this that will not interfere with timing of this loop
I want this to run all the time and the LED will change how it blinks based on the variable.
How do i do this? Should i be using Cognew?
It's Only A Stupid Question If You Have Not Googled It First!!
REPEAT XB.RxFlush Celc := (((ADC.in(0))*3300)/4096-500) 'the MCP9700 will be connected to possition 0 on the MCP3808 PC.str(string("we are sampling the temp now -- ")) PC.dec(Celc) PC.tx(13) BatteryVolts := (ADC.average(1,16)) 'the battery will be connected to possition 1 on the MCP3808 and will have a divider circuit to monitor a 12v battery.' PC.str(string("and now the battery voltage is -- ")) PC.dec(BatteryVolts) PC.tx(13) IF WaterLevelFlag == 1 XB.str(string("EEEEE")) XB.delay(500) Emergency ' motor needs to close immediately
PUB LEDSTATUS | Flag Case Flag 0: REPEAT 20 !outa[noparse][[/noparse]SLed] XB.delay(100) !outa[noparse][[/noparse]SLed] XB.delay(200) 1: REPEAT 20 !outa[noparse][[/noparse]SLed] XB.delay(250) 2: REPEAT 20 !outa[noparse][[/noparse]SLed] XB.delay(50) 3: REPEAT 20 !outa[noparse][[/noparse]SLed] XB.delay(500)
The remaining issue is that your LED status method looks at a local variable (Flag) which isn't very useful (for starters it's undefined). I assume the flag is to be updated by another part of your program, in this case make Flag a global variable (in the VAR section) or pass its address as a function parameter. Make sure that if you use a local variable it stays alive, global is probably best.
Also, could you please reformat your comment in the code section, it makes the page too wide and the posting hard to read.
1) How does Flag get set?
2) How does XB.delay work? If it uses any global (VAR) variables, you may have problems with two cogs potentially changing the same variable at the same time.
Each cog has its own I/O registers. You'd have to initialize DIRA in the 2nd cog for SLed.
The code in the 2nd cog has to not exit so you need some kind of REPEAT statement around the code. If it exits from the method, the cog stops.
