BS2 with Serial to Usb - randomly gives Communication error
Hello, I'm just starting out.
I am using BS2 HomeWork board connected to a Sony VAIO laptop with a Serial to USB-A converter. When I'm compiling/uploading a new firmware (program); randomly I would get a "Communications failure!" error. As i retry, it gets uploaded. Would that be a:
-damaged board
-most likely a problem with the serial-to-usb converter (and windows not reacting to it correctly)
-damaged board
Check this link. I had the same problem:
http://forums.parallax.com/forums/default.aspx?f=5&m=266940
DJ
Or maybe it's my Vaio, who knows...
Parallax Engineering
Is ANYONE here using the cable from radioshack (Gigaware) and having issues with it, or not?
- Stephen
