Pressing "play" on an iPod with BS2?
Hi everyone,
I am just starting off with my new BS2 and I have this question:
I would be very interested in the option of controlling third-party devices with the BS2 (by disassembling the devices and connecting them with the module).
I have this question : Is it possible to "click" any button like "play" on an iPod with the basic stamp? Would the right way be to connect a transistor's two ends to the two parts of the circuit (replacing the button on the iPod); and the third pard being connected to the BS2 so that it can receive a current thru P0-P15 and "press" the button?
Would such technique let me integrate the BS2 with other devices in such basic way?
There are quite a few questions just like this answered here. It seems the most popular is take the IPOD apart, solder wires to the play button and fire it with a tiny relay controlled by the Stamp.
Above mentioned "Modification" is entirely capable of ruining an IPOD, so plan ahead and be careful.
"puff"...... Smile, there went another one.
Parallax Engineering
http://nuxx.net/wiki/Apple_Accessory_Protocol#iPod_Remote_.28Mode_2.29
I remember a while back someone hacked the headphone control on Hackaday.· They may have deleted it but I need more time to find it.
I remember what it was like to have a boat-
load of ambition and undeveloped skills.
Here is a link to a tiny relay.
http://www.radioshack.com/product/index.jsp?productId=2062478
Now the last time I took apart an iPod, I was not convinced to
try and solder to the switches but if you did, you could do
something like this attached pic.
Uploaded with ImageShack.us
Then use what ever method you want to send pin 0 HIGH
you could use a button push, or a power on timer , or a
RFID car reader.... Just for example
From···· ·Northwest· ·· Indiana-
Where·· the · introverts · stare
at··· there·· ·shoes··· and·· the
extroverts stare at your shoes!
You don't even need·the user·elbow potentiometer as an input device, just program the Stamp to drive the servo 90 degrees when triggered by, perhaps another pushbutton. Or an IR remote signal.
See, the IR remote triggers the IR sensor which triggers the Stamp wait routine which triggers the servo routine which moves the arm which is connected to the hand which pushes the PLAY button. So simple!
OBC's Gramps has got it goin' on!
Before you criticize someone, walk a mile in his shoes. That way if he gets angry, he'll be a mile away and barefoot. - unknown
