EEPROM Memory Monitor (Modified Monitor Demo)
Hey everyone,
I was recently working on a test procedure for EEPROMs to verify specification timing, etc.·when I needed a convenient way to display the current contents of the EEPROM.· I really liked the memory monitors from the old days, and even for EEPROMs if I read one into my device programmer and did a memory dump the listing was the same format.
I remembered Chip Gracey had written a Monitor Demo back when the Propeller was first released.· This demo could display any of the global 64KB of memory in the Propeller (32K ROM / 32K RAM) and even let you edit the RAM, much like the cartridge based units of say the Commodore 64 days.· So I took a look at Chip's Monitor object and realized changing three lines would allow me to do all the same functions on an EEPROM as his original did with the Propeller memory.·
Attached below is the ZIP archive with the necessary files.· Hopefully some of you will find this as useful as I did and you old-schooler's should even feel a little nostalgic.·
Parallax Engineering
