ASCII to Hex
I need to accept a two byte input from Hyperterminal via Uart object. This input will be ASCII. I then need to convert this input to hex for output on a shift register. From what I can tell, there is not a single method for doing this. I am considering bringing in the ASCII character, then using some sort of array as a look up table. Is there a simpler method? Inputs will range from 0x00 to 0xFF (the user will not need to input the "0x" of course.
George
George
If you treat each incoming byte as a separate character and apply the pseudo code below, then after the two bytes, the result in 'H' should be what you are after....
Where:
N is the ASCII value
H is the Hex value that you want
Beau Schwabe
IC Layout Engineer
