Smoking PING :)))))
Something really wild happend last night. I had my robot with the robot control board and 3 ping sensors set up fine. It roamed the house and things where great. Last couple of days I was a bit busy so the bot just sat on a shelve. Last night I got a friend of mine comming over that wanted to see the Bot. So I put it on the floor and switched it on. Nothing happend, power led went on, ping leds went on and next smoke came out me left and right ping sensor!
I checked everythig but al seems fine. It just has the 3 pings connected and 2 motors all hooked up in the right way.
Anyone a clue why my robot control board is starting to fry ping sensors? Will be this be warranty? Did anyone ever encounter something like that?
Dave
Dave Andreae
Parallax Tech Support·
Send you a mail Dave.
What I think is strange (well, maybe im not seeing things right) is that both sensors and board are gone. I would imagine that a shorcut would·kill one of them. In this case I saw the left and right sensor go up in smoke but the center one didn't. Even if it was overvolting the sensorports why on only 2 instead of 3 and why did the mrs1 board blow up? That should be able to handle up to 24 volts and I'm running it on 11.1. I'm 100% sure that nothing touched the board (as it sits on the middle deck and is protected by wood).
I've had small switching regulators fail 'shorted', putting the full input DC on the 5 volt line, which can destroy a lot of chips. I've NEVER had a "linear regulator" fail shorted -- but this is just my experience.
They have a special machine at Parallax called the RMA that can re-inject "factory fresh SMOKE" back into the leaking devices. They·fix the leaks and send them back to you.·Give tech support a call and they will give·you the details.
Tech support at Parallax has always been·super great·any·time I have had a problem. I once had both "SMOKE" and "Flames" leak from a MSR1 board Prop chip, and the RMA machine re-installed both, it is still working today!!!
