Can I connect both ext power and USB wire on BS2pe board at one time?
new to BS2pe.
I want to use ext power supply and read data from BS2pe's EEPROM through·USB to my computer.
My question is :Can I connect both ext power and USB·wire on BS2pe board at one time?Is it OK?If not,what will happen?
Thanks!
Thanks!
- Stephen
I'm assuming your external power is coming in through the two-pin connector on the MoBo, or via Vin from daughterboard socket A, right? If, instead, an external regulated +5V is being supplied directly to the +5V bus, you should remove the power source jumper from the MoBo entirely.
Thank you .I find it OK
