Wii Numchuck Board Connections And Voltage??
Hi all,
I have a wii numchuck module that has been sitting around for a while. I removed it from the plastic carrier and no longer have the connections to the plug as described in the object. Can anyone help me with which ones are witch?
I have the wire connector comming off with the following wire colors·in order from left to right.
Brown - Red - Orange - Yellow - Green - Blue - Black
Also what is the correct VCC supply voltage? 3.3v or 5v?
Thank you,
TJ
I owe everyone here a bunch, So thanks again for answering my dumb questions.
Projects. RG500 ECU system. PropCopter. Prop CanSat. Prop Paste Gun.
Suzuki RG500 in a RGV 250 frame.
Bimota V-Due (Running on the fuel injection system)
Aprilia RS250
Thank you,
TJ
Aprilia RS250
About color code, it depends on where you purchased it....
I'll tell you my color codes:
On the board I have a 6 pin connector, numbered 1-6, and a + corresponding to pin 1.
here we go..
Pin1, red, Vcc
Pin2, not connected
Pin3, yellow, SCL
Pin4, green, SDA
Pin5, white, GND
Pin6, black, not used, it is shorted to pin 5.
I hope it helps..
Massimo
