wireless project
what would you advise to use I have 12volts on one end of the control side and then 3ft away I have the output of about 2 amps and want to control it wirelessly were will i get my power source, thinking about solar or wind energy, what is your advise, is there something out there that can transmitt energy?
Thanks, Toby
Thanks, Toby
- Stephen
Thanks, Toby
http://www.wirelesstowlights.com/
8-AA bateries and your good to go!
Thanks, Toby
http://www.siliconsolar.com/12v-solar-battery-charger-15w-p-133.html
and a SLA battery. You could splice the power into the wireless link I sent earlier with the proper voltage regulation.
Honestly, a wired version is sooo much easier. Wiring is a no brainer. There is gigabytes of wiring help out there. I do it all the time. Have owned and wired at least 6 trailers.
Jim
By trying to replace 3 feet of wire with a wind-powered wire-less controlled solution, you're making the solution WAY more complex than it has to be. Not to mention cluttering the solution with unintended consequences -- like how do you have trailer lights when you've stopped moving?· Or if solar, how do you have trailer lights in the dark?
- Stephen
basically it was two seperate coils acting as a transformer but spread about at both ends of a bench, his method was used to teach induction and on the "secondary" coil were insulated probe with which he drew an arc which he then proceeded to show it burning into a piece of wood, the device was in effect a step up transformer.
Obviously AC and no use to the OP but just to prove that you can transmit over distance
