propeller flashing protocol
I am not finding the documentation on how the propeller is loaded on power up. I need to make my own software (in C) that loads a binary file in the propeller RAM and run it.
Where do I find info on this?
Also, do you guys know if built-in-loader has commands to program the EEPROM or parallax cheat and load a software on power up that in turn programs the EEPROM?
·http://www.parallax.com/tabid/832/Default.aspx
No one has made a linux/mac loader for propeller? Maybe in java?
I guess I have to figure out the 3-bit protocol on my own...
Thanks guys
Its everything you need to figure out what to do. I would just read the prop loader code as it is what your application will have to do. The bootloader code is the thing that boots the prop chip.
You know, someone else asked these same questions before. You should search the forum for this topic and PM that person.
Nyamekye,
The code only loads to RAM. If you wish to load into EEPROM, you need to send a different command, and also allow some delay for EEPROM write and verify.
http://forums.parallaxinc.com/forums/default.aspx?f=25&m=420881&p=1#m421143
http://forums.parallax.com/showthread.php?p=875516#post875516
On power up, the host has to send 250 bit of LFSR. These are constant array (correct?) but to save memory, they are calculated on power up.
Now, once the propers receives the numbers and they are correct, the will now send its own 250 bit LFSR which is a constant array (correct?) but the propeller calculates them at run-time to save on memory.
So in theory, it is easier to just have a constant array in my program for the LFSR so I wouldn't have to calculate it every time, correct?
Finally, after propeller and host exchange and verify the LFSR, a simple command can be sent to load the program in ram.
www.fnarfbargle.com/bst
"I mean, if I went around sayin' I was an emperor just because some moistened bint had lobbed a scimitar at me they'd put me away!"
It's easy to calculate the LFSR bit by bit as you send it. You can do it in a constant array, but it's not complex to calculate on the fly.
