Another stupid question.
Okay, this one should be very easy. When you are using a 64 kilobyte eeprom for your main boot eeprom, does the upper 32 kilobytes of memory get erased IF you reprogram the eeprom? I found out that is so much easier to use just one large eeprom for data and program code, instead of two smaller ones......Thanks in advance
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
