Best FTDI circuit for Propeller?
I'm working with the FTDI232RL and the Prop. I've done a proto and everything is checking out - I implemented it in the same way the DLP-Prop implements it. But I wanted to get a second opinion on the FTDI portion of the circuit;
(full schematic is attached)
I'm not sure what causes reset problems on the FTDI circuit on the Protoboard, but will this circuit have the same problems?
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
http://forums.parallax.com/showthread.php?p=847290
An inexpensive alternative is a jumper on DTR, which could be removed when not programming.
Post Edited (DynamoBen) : 6/2/2010 5:52:41 PM GMT
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
