servo motor control by using potentiometer
hello guys
i am going to do my final year project regarding the servo control
because i am going to construct a robotic arm
basically,i need some guides to do it
i need some guidance how the potentiometer can control the servo rotation respectively by rotating the potentiometer probe
i've been watching some videos on youtube where got some people already succesfully do it
so I really appreciate if someone can help me in this
roughly,i am going to do it using 8051 as the brain and for sure i need adc to convert the continuous signal from the potentiometer to digital signal
thats the only basic thing i know
really need some guidance from some experts here
thank you very much~
The "Robotics with the BoeBot" tutorial describes how servo motors work and shows how to control their movement. The same process would be used with the 8051. The Stamp's PULSOUT and PAUSE statements are used to generate the control pulses for the servo and you'd have to do the equivalent with the 8051.
You can find the Stamp documentation and tutorials here: www.parallax.com/tabid/477/Default.aspx
Also check out Chapter 5, Activity #4 in What's a Microcontroller. You'll have to modify the code for your 8051, but the basic concept it there.
Let us know how it goes!
-- Jessica
Jessica Uelmen
Education Department
Parallax Inc.
basically,the BASIC STAMP is a microcontroller right so it means i do not need the 8051 anymore?
in the example, it shows only one pot and one servos
is it applicable for more pot n servos pairs?
A two pot/ two servo program is only a little more complicated than a one pot/ one servo program. You just have to be careful to keep to a 20ms cycle because that's the way servos work. You could probably handle 3, but there just isn't enough time in a 20ms cycle to handle much more than that.
yesterday, i did some study on the basic stamp and if I'm not mistaken, it is much more easier for me right to use the basic stamp microcontroller instead of 8051?
there is also some tutorials on how to control the servo also
so i just want to know,is it good for me to get the board of education by parallax
and i just want to make sure,how many pairs of pot n servos the the board of education can handle at one time?
because my project need to use 6pot n 6servos
is the board of education can handle all this?
thank you
After thinking about this a little more ... I think a Basic Stamp could handle 6 pots with 6 servos, but the response time to changes in the pot positions would be slowed down. A servo control pulse is, at most, 2.5ms in width. 6 of these would take 6 x 2.5ms = 15ms. That leaves only about 5ms in the 20ms allowed before the next servo pulse would have to be sent. It might be possible to read the value of one pot in that time using an RCTIME statement as shown in the Stamp Manual. By reading one pot each cycle, you could read all the pots in 6 x 20ms = 120ms. That's about 8 readings a second. That may be fast enough for you. You wouldn't get a high resolution of the pot setting. You'd do better using an external Analog to Digital Converter, one with 8 channels (for the 6 pots). That could certainly work for what you want.
Here's one example of an 8 channel ADC:
www.parallax.com/Store/Components/IntegratedCircuits/InterfacingChips/tabid/613/CategoryID/78/List/0/SortField/0/Level/a/ProductID/573/Default.aspx
Post Edited (Mike Green) : 6/9/2010 3:46:00 AM GMT
i already watch video on how servo are controlled by propeller but based on what I see,all the servos are automatically and simultaneously rotate
can the propeller do as I expected which is each pot control their respective servo,without interrupt other servo movement?
