How to connect a BASIC Stamp super carrier board to an alarm clock.
Hey guys, I would just like to know how I would go about connecting a BASIC Stamp carrier board to an alarm clock. Would I need a special alarm clock and what plugs would be needed? Thanks.
SparkFun has a breakout board for the real time clock that includes a backup lithium battery and there are plenty of examples of its use with a Stamp.
alarm clock, will turns off the alarm. You could connect the relay to the alarm clock's buzzer, when relay is active the buzzer will be trun
off, or you could connect a read-relay to the alarm colck's snooze button, to active the snooze function. It's all depend on the type of
your alarm colck.
Post Edited (electrosys) : 6/2/2010 12:13:15 AM GMT
BTW, I don't understand the referal to Raisin Bran or the YouTube video, although the young man is quite talented.
wiresalot
Parallax Engineering
Exchange the alarm buzzer or bell with an LED or infrared LED and use a sensor to sense when the alarm goes on.
When I say replace with an LED, you will need to specify a bit more on the specifics of the actual alarm clock you are using. Wind up? Radio Alarm? Buzzer? Bell? kind of hard shooting in the dark here.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
