Quadrocopter / drone
I am looking for a way to build a quadrocopter using a propeller robot control board.
I am using a memsic2125 accelerometer for balancing.
I need to know what parts i still need and where to get them.
For example: i need motors. As far as i could find they have to be brushless. So what do i need to run them on the propeller?
And how much power do the motors need?
I found these.. Are they powerfull enough?
www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4700&Product_Name=hacker_Style_Brushless_Outrunner_20-22L
How about remote controll? I have a toy helicopter laying around (3d) can i use that atleast for now? A ps2 controller would be nice too but i think the signal is too weak. Is there any way to boost it?
I need everything to be cheap. Allthough i don't want to underpower it. It needs to carry a small wireless camera.
About 500 grams max.
What sort of batteries should i use?
I need a descend flight time. But dont want to pay above 35 euro/45 dollars.
[url=http://][/url]
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
[url=http://][/url]
- Stephen
Have you considered this place - they may be able to help you get stuff that works for not much dough:
www.hobbypartz.com/
·http://www.google.com/#hl=en&source=hp&q=Quadcopter+site%3Aforums.parallax.com&btnG=Google+Search&rlz=1R2ADFA_enUS371&aq=f&aqi=&aql=&oq=Quadcopter+site%3Aforums.parallax.com&gs_rfai=&fp=2a0dbe5263c501d8
This thread has been running for a few months.
- Stephen
I tried doing research. But the info i asked i could not find.
@hover and Franklin - I do know how to use google, and if you can only make this kind of jibberish.....
Please Shut Up!!!
If you don't want to " do the work for me" just don't reply.
I'm really getting sick of people saying this (expletive)!!
@Scope - thanx for the link. Very helpfull!
Check out the Propeller Wiki·and contribute if you can.
Anyway i willcheck the link on another computer.
Thanx again!
It may be too much to fit on the Safari browser. Just go to Google and use "Quadcopter site:forums.parallax.com" as your search criteria. Using "xxxxxx site:forums.parallax.com" is much better than using the Forum search.
From your first post, it did sound like you wanted someone to give you an entire parts list for a Quad, minus the Propellor Robot control board.
Do check out the Quadcopter thread:
·http://forums.parallax.com/showthread.php?p=890157
That link should work on the iPhone.
Jim
Making the thing fly with only an accelerometer will be hard, if not impossible.· Accelerometer readings are VERY noisy, especially with motor vibration, and they're not an accurate measure of angular velocity.· For example, if you were hovering, and pushed the thing sideways with your hand, it would read an acceleration in that direction.· Along with the gravity vector, it would now believe it was tilted, even though it was still perfectly vertical.· Gyroscopes don't have this problem.
For motors, you'll need brushless motors rated at ~1000Kv (also called RPM/Volt), and you'll need motor controllers capable of 10 or so amps of power, depending on how heavy the thing is.· I'm running 18A controllers and rarely use it all.
On my next quad, I'm trying these:
http://www.hobby-lobby.com/brushless_skatty.htm
I've used them before on planes, and they're powerful and light, so they should be ok.· They should draw significantly less than 10A.
For a motor controller, find a brushless ESC that allows for fixed throttle range programming.· Otherwise, the throttle response will "adapt" on the fly and mess up your balancing code.
I'm using these:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=5449&Product_Name=TowerPro_n20_Acro_Brushless_Speed_Controller
They'll handle up to 20A, can be PWM'd at 200Hz (maybe more - I've never tried) and they're dirt cheap.· To program them, I recommend getting the programming box.· Using the throttle and "counting beeps" method takes forever, especially with four of them.
Jason
To figure out how much lift you'll need, you have to figure out how much total weight you'll be carrying. My batteries are ~150g each (x2 for added time), the motors are ~60g, and the controllers weigh ~20g. Add a little fudge for wiring and propellers, say ~20g:
4 x (60 + 20 + 20) = 400g for motors + controllers
2 x 150 = 300g for batteries
500g for the camera
= 1200g weight, less chassis and propeller board.
At 600g thrust for those motors (times 4), you have 2400g of thrust, or another 1200g to play with for the chassis and brain before it won't lift itself. Don't use all of that though - ideally you want at least a 3:2 ratio for thrust:weight. If you don't have that, you won't go vertically very fast.
Jason
That is the onfo i needed.
One more question though:
since you build one.. .. Can you tell me what parts i need? I read something about a flight controller? Do i need one? Or is that just the receiver for the rc?
Is there someone in the netherlands who can help me build it?
Please visit the other thread. There is much talk about motors, ESC's and the like. There have been a few tested with different weights.
Jim
When I say "flight controller", I mean the Propeller chip & software. Assuming you want to control it manually, you'll need an R/C receiver and a matching transmitter. If you read through the Quad/Hexa thread, or "Propeller with Propellers" thread in the Completed Projects section, you'll find some useful stuff.
Jason
I have a small rc helicopter and can fly that. It's one of those with 2 propellers above eachother, and that can hover.
I can fly with that. Is it kind of similiair to fly a quadcopter?
I do want to fly it manually but also want to have the option to expand later to whatever sensor or so.
So the propeller will be needed. And i need it to hover when i let go of the controlls so i can manage with the camera.
I'm not very anvanced in programming spin but hope you can help me a bit. Maybe i can have a copy of your code? Do you have a basic code for remote control? And what sensors do i minimally need to get a stable flight with your code?
What esc brushless controllers are compatible with proppeller?
Post Edited (Botdocter) : 6/3/2010 12:43:50 AM GMT
Regardless of whether or not you want something self-stable you'll need a controller chip on board to do the R/C input and gyro mixing. A quad rotor is inherently unstable - Without on-board gyros to correct for minor turbulences it's completely unflyable. Mine currently flys like a slightly skittish helicopter, so your coaxial rotor will be about the same, possibly even more stable than what my code will get you.
That said, my code hasn't been fine tuned, I still get a decent amount of vibration from my motors (which hampers the sensors), and I haven't done much with it since I got it stable enough for -me- to fly it. I don't actually care if it's hands-off or not because I wanted it to fly like a heli, but it shouldn't be that difficult to improve the code once you get something that works.
I'm currently working on my next one, using all digital components (ITG-3200 3-axis gyro, and a 3-axis digital accelerometer). I hope to have something to show in the coming weeks. I'm going to try to assemble a jig with just two rotors on a kind of "teeter-totter" so I don't have to worry about it crashing, hook it up to a PC, log everything, and start working on a better flight controller. I have the control board working already - I just have to build the test rig.
I'll post more as I get to it, and you're welcome to ask me questions, either here or via PM. I won't write it for you, but I'm happy to steer you. [noparse]:)[/noparse]
Jason
Maybe its too simple minded from me but i thought it would work like this.
Make it hover, in place. That shouldn't be that hard is it? Just calibrate everything to 0 and let the gyro and accelerometer do the rest. Then when throttle is used, the 0-angle is changed to y-30% or x+30%.
The exception to that rule is the IMU that CessnaPilot is working on, which uses some very crazy math to integrate the readings from 4 accelerometers to accurately model rotational and translational inertia to maintain a real world location estimate. I think I'm going to have to look at his stuff at some point, 'cause it's over my head, but damn cool.
The reason so many of these things have gyro / accelerometer / GPS / compass / altimeter / PING / IR sensors in them is because that's generally what it takes to make them hands-off flyable.
Motors and propellers vibrate, and they blow "chopped" air across the arms they're attached to, which also causes vibration, affecting the sensors. Close to the ground you have ground effect turbulence to deal with, and if you're timid with it, that's where you'll be trying to fly. I'd recommend trying your first few flights in the middle of a baseball diamond or parking lot. [noparse]:)[/noparse]
Note that I'm not trying to scare you off it - I'm just trying to set your expectations reasonably, and that's all. If you can fly your coax you'll be able to fly this thing once it's reasonably well behaved, but it might take a bit of tuning to get it there, that's all.
Jason
450 grams for complete frame inc. Motors elektronics
300 grams for double batteries
still 450 grams to go. I found a small 5mp camera that i'm going to use.
Atleast then i have a working qc to go from with thw propeller( chip)
what do you guys think about this set?
www.cnchelicopter.com/servlet/the-1652/Xaricraft-X600-dsh-D-X600D-aircraft/Detail
But now i need a proper compatible radio set for it.
Wich one is compatible? I want to spend max $60
i think i want 2.4ghz because its faster but i also have a 2.4ghz camera. Will it interfere?
The radio has to be a set. So receiver and sender.
Spektrum DX5e
Reciever is extra. I myself, would go for a DX7 :
·http://www.hobby-lobby.com/spektrum_dx7_transmitter_only_283133_prd1.htm
If you are going to do any serious Heli stuff you need a transmitter that can support Heli's.
Here is a 6-channel w/ reciever:
·http://www.hobby-lobby.com/dx6i_full_range_transmitter_ar6200_rx_md2_no_servos_3769_prd1.htm
You would have to go with a 900 Mhz or 1.2 Mhz camera because it will interfere.
Don't expect a good TX/RX combo for $60.00. The would be the price of a ground based 2-channel system for cars.
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8991&Product_Name=Turnigy_9X_9Ch_Transmitter_w/_Module_&_8ch_Receiver_(Mode_1)_(v2_Firmware)
I have a clone - flysky but I dont know yet how reliable it is and what range you get
