Hanno's IODreamKit - DreamKit:TNG Discussion Thread
As some of you know (from Hanno's post in another thread) I will be producing the IODreamKit.
Hanno and Brian came up with the initial design, and I've recently taken over the project. Now that I've finished the designs I wanted to send in for prototyping PCB's before UPEW, I will be spending time on IODreamKit. I may bring the original DreamKit prototype to UPEW...
Personally, I prefer through hole designs - not only does it allow easier repair in case one of the chips magic blue smoke escapes, but it also allows easier assembly. After a discussion with Hanno he told me I can redesign the board however I like [noparse]:)[/noparse]
The original IODreamKit design featured:
1) one 100Msps 8 bit ADC
2) one five bit 20Msps arbitrary waveform generator
3) eight channels of 12 bit ADC (MCP3208)
4) two channels of delta sigma waveform generation
5) eight digital output channels that can sink up to 500mA
6) eight channels of buffered digital I/O
Hanno's IODreamKit images: hannoware.com/dreamkit/
Hanno's IODreamKit forum: forums.hannoware.com/viewforum.php?f=6
Here are the preliminary specifications for the "standard" IODreamKit 2:
2) one seven bit 100Msps arbitrary waveform generator (NOTE 1)
3) eight channel 100Msps Logic Analyzer inputs
4) eight channels of 12 bit ADC (MCP3208)
5) two eight-channel expansion ports (MCP23S17) for high current output module and optically isolated input module
6) two combination triggers / counter input/outputs / delta-sigma output
But wait... there is more... you get two free Ginsu knives! (just kidding)
Actually, I think it is more exciting than that.
IODreamKit 2 will be modular!
The new design accepts up to three high speed 8 bit modules, in any mix of:
A) 100Msps ADC module
100Msps 7 bit DAC module (8 bits are possible, but serve no purpose due to 1% resistor tolerance)
C) 100Msps Logic State Analyzer module
D) 8 channel PWM DAC module
E) ... additional future modules ...
The new design also supports:
A) 7 additional MCP23S17's daisy-chained from the SPI port used for the on-board MCP23S17
six additional SPI ports (using same standardized pinout that future Mikronauts modules will use for my entire product line)
C) two ALT connectors for the on-board MCP23S17 supporting future soon-to-be-announced Mikronauts industrial modules (oops!)
D) one analog connector for the on-board MCP3208 supporting future soon-to-be-announced Mikronauts analog conditioning module
Sapieha will be doing the PCB layout, so it is pretty much guaranteed to be a work of art [noparse]:)[/noparse]
Yes, this DOES mean that you can (with the purchase of additional modules) use IODreamKit 2 as:
1) Three channel 100Msps scope (0-3.3V)
2) Three channel 100Msps DSO
3) 24 channel 100Msps Logic Analyzer
- or any mixture of modules you care to plug in!
Oh - and support a TON of SPI I/O, and my upcoming industrial modules...
I'd love to hear your feedback - the design is not cast in stone yet, I plan on sending in the prototype PCB just before I leave for UPEW... so your suggestions can still be heard!
I really liked Brian's version; but I wanted this version to be modular.
I am very excited about this project...
NOTE 1:
100Msps DSO output has a small output glitch approximately every 800 samples, if there is not somewhere 4 consecutive samples of the same - or only 1 LSB different - value in the waveform.
50Msps DSO output would be glitch free. Yes, I use the video output circuitry to achieve this.
Theoretically 128Msps output (or even 150Msps) would be possible (with aforementioned glitch for 5 samples), but there would be aliasing errors due to phase accumulation; and PPL's may burn out at >128Msps. Not worth it.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
Post Edited (Bill Henning) : 5/31/2010 11:10:59 PM GMT
NOTE 1:
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Thanks for the feedback!
soon = between now and UPEW
I PM'd you... we really need to talk.
If you can say, will it be based on the ViewPort Engine?
I really don't want to retire my new Propscope so soon.
Jim
IODreamKit:TNG = Hanno's Software + Bill's Hardware
After looking at the original DreamKit hardware - which, by the way, I thought was great - Hanno and Brian did a great job - I had a chat with Hanno to find out if he minded if I redesigned the hardware.
He did not mind at all... so I just scaled down a design I had been working on for about a year for a high end expandable bench instrument in order to keep production costs lower (most people don't need all the features I was planning, nor would they want to pay for them) and added optional high current outputs. I was careful to keep the "spirit" of the original IODreamKit alive in TNG.
You can think of IODreamKit:TNG as "MorphLAB Jr."!
Should the full MorphLAB eventually see the light of day, ViewPort will be the PC software for it.
Don't retire your PropScope! IODreamKit:TNG is not a direct competitor for the PropScope, it is more of a complementary DIY'er product!
Post Edited (Bill Henning) : 6/8/2010 1:45:09 AM GMT
That's great news. Two power players teaming up! (Make that 3, Sapieha is quite the layout king).
I expect a nice 12 page glossy catalog to be at UPEW!
Jim
Sapieha is "THE" PCB King!
Umm... only 12 pages?
Let me check.
Opening OpenOffice....
The "Mikronauts Summer 2010 Product Selection Guide" - which I started recently - currently stands at 28 pages, and likely to grow to about 50-60 by the time I finish adding photo's and text. There are currently 25 products in it, and I know I have to add at least one more [noparse]:)[/noparse]
Bill
Where do you find time for sleep and the wife? [noparse]:)[/noparse]
Jim
Wife? Oh! I remember now... I see her in the morning, and at dinner... sometimes on the weekends too...
It is not QUITE that bad, but I have been working too much. I think it will be worth it!
re: IODreamKit:
When is this product scheduled to be released?
I didn't see it on the HanoWare website or on your website.
Bob
We still intend to bring it out, but it will take a while.
John Abshier
Graham
My current plan is to finish qualifying the designs I introduced at the last UPEW, then tackle IODreamKit:TNG
I've been delayed with the new designs due to 120hrs+ of consulting and some family time.
The good news is that my 1Gs/sec 100MHz bandwidth scope, that I will need to test IODreamKit:TNG, has arrived, and works VERY well
best regards
Stefan
This is an older thread but I hope the DreamKit is still alive. I am also very interested in this project and its potential for an application we are working on.
Grant
Thanks for the interest. After I am finished with my current boards, I will work on the design.
One thing is fairly certain - it will be a through-hole main board, and most modules will be through-hole as well.
I am about half way to finishing the boards I announced at UPEW 2010... and while I it is not finalized, I have been thinking about IODreamKit:TNG over the last few months.
I have concluded that my initial plans - to make it totally modular - would make it cost prohibitive for now.
Hanno's original IODreamKit had the following features:
I really wanted to make IODreamKit:TNG modular, so people could pick/choose the feature set, however the cost of making so many different PCB prototypes, testing them, and going to production with the main board and four modules would take too much time, and too much money.
I know Hanno really wants to get a version out there (so do I) so I've decided to simplify the design, which as a nice side effect, will reduce costs as well!
The current feature set I am looking at is:
1) one 100Msps 8-10 bit ADC
This would be a surface mount part, and I while I am leaning towards the ADC08100CIMTC Hanno likes, I am looking into alternatives as the ADC costs more than a Prop!
Instead of an SMT resistor network, I am thinking of a simple seven bit R2R driven by a 74HC574 (so I can latch the value)
By adding the latch, I can allow an alternate use for the 7 pins it will connect to - namely 7 more logic analyzer or trigger channels.
100Msps requires one spot in the waveform of up to 512 samples where the value stays constant for 4 clock cycles.
These would go to an EXP style connector, so if you needed to, you could use different modules in it, instead of its default "logic analyzer input" mode.
This ADC would be on a shared bus with the MCP23S17 below, and is intended for low speed input
5) two eight-channel expansion ports (MCP23S17) with "EXP" style connectors
This would replace the high-current driver on the original design; instead you would get two connectors that could take my DIG-8-IN-V opto isolated module, or my DIG-8-OUT-V SSR module... or could be used for any other use you may have for parallel I/O
6) Five SPI expansion connectors for hooking up more SPI devices
7) I2C expansion header, same as all of my other boards
8) 5 pin "H-COMM" header, fully PropPlug compatible, for a PropPlug or SerPlug or other compatible module
The feature set above would allow me to keep some of the flexibility I intended for the fully modular design, while reducing the size of up-front investment I need to make to bring it to market.
I like the return to the initial concept:
- Propeller
- high speed analog and digital I/O
Layed out by Sapieha, developed by Bill, and supported with real-time graphing and datalogging with ViewPort this will suit all kinds of applications!
Hanno
Not forget some design additions by Sapieha
I'd better test it after finishing the current boards.
The propeller has the potential to realise a similar number of virtual instruments with only limited additional support chips (fast A/D). The real challenge is good software support, and I like the "waveforms" software. http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,66,849&Prod=WAVEFORMS I love the way they handled the digital pins, like a virtual PPDB.
