Tda 7052
Hello everybody,
i am new in the world of the Propeller chip and need some help from the experts here in the forum.
My proto board is working without any problems (RS232, Pal Video etc.) and now i want to hear some audio from it, so i want to connect a TDA7052 to my Propeller.
My problem is now that i have never used this ic before so i doesn't know how to connect it to the Propeller.
The power connection are clear but i have my problems with the signal.
Can someone please help me?
Regards and thank you
Florian
Florian
Leon Heller
Amateur radio callsign: G1HSM
Leon Heller
http://pdf1.alldatasheet.com/datasheet-pdf/view/19419/PHILIPS/TDA7052B.html
Why did I think a new, more challenging, job was a good idea ??
I have checked the version and it is a "A" Chip.
My problem is that i doesn't know which RC combination i need to attenuate the signal.
Btw: sorry for my bad english.
Leon Heller
This is not tested, only put together according the datasheet. Perhaps you need to play a bit with the
resistor values to get the right voltage swing (volume). Or you insert a 10 kOhm Poti instead the 3.3k resistor.
Andy
Leon Heller
