monitor power off. how does the pc signal the monitor to turn off?
I want to build a circuit that activates when windows tell my computer monitor to turn off. any ideas how i can detect this? Obviously I need a femal DVI connector to plug into the computer and a second male DVI connector for the monitor to plug in so the video signal still goes through but what pins do I need to monitor?
Lots of propeller based products in stock at affordable prices.
90 * 2 = Pi
90 * 2 = Pi
dvi does not have id pins like vga has. it does however have 2 i2c pins so that probably took the place of the 3 id pins on vga. I do see that pin 16 is for hot plug detection so it may be as simple as detecting if data is being transmitted or not and the monitor uses pin 16 to tell the difference between unpluged and turn off.
my logic analyser is way to slow to scope DVI signals
Parallax Engineering
I am not trying to shut down the monitor. i am trying to detect when windows has shut down the monitor. I want to shut down my stereo when the monitor gets shut down.
"Are you suggesting coconuts migrate?"
