IRFZ46N MOSFET versus IRLZ34N
I have not used MOSFETs before and have been reading various threads pertaining to them.
I want experiment with driving 12volt motors without an H-BRIDGE.
I read that the IRLZ34N was a good "choice for control by logic circuitry"
http://forums.parallax.com/showthread.php?p=759109
I just removed sixtreen IRFZ46N·MOSFETS from an old·Pure Sine Wave APC UPS and was trying to compare datasheets but I am defuddled by all of the specifications.
They are both 55V but the IRZ46N has a "ultra low" RDS(on)·of 16.5m ohm (0.0165 right?) versus 0.035 ohm
Are there any other·significant specs that I should compare?
Also, can you·drive them with PWM signals to control the motor's speed?
Datasheets:
http://datasheet.digchip.com/232/232-12816-0-IRFZ46N.pdf
http://datasheet.digchip.com/232/232-13687-0-IRLZ34N.pdf
Thanks for any help/info!
Post Edited (ronczap) : 5/29/2010 10:40:43 PM GMT
Datasheets:
PWM signals are just rapid on/off pulse sequences. The ratio of on-time to off-time is proportional to the average current conducted. A motor or incandescent lamp provides some inertia so the pulses "smooth out".
I see from the Drain-to-source Current/Gate-to-source voltage charts that the IRLZ34N·does source more current at 5 volts.
Datasheets have so much info that it's hard to know what to look for - especially if you don't have a strong electronics background...
Post Edited (Ron Czapala) : 5/30/2010 12:15:12 AM GMT
- Stephen
What do you mean by a MOSFET driver -·another component between the microcontroller and the MOSFET?
What MOSFET(s) would you recommend to drive directly from a microcontroller·using PWM?·· The IRLZ34N?
What if you wanted to control the positive line - a P channel, logic level MOSFET?
· Ron
Yes, something like the TI TPS2814P, for example, or one of Micrel's drivers.
What MOSFET(s) would you recommend to drive directly from a microcontroller using PWM? The IRLZ34N?
It depends on the micro's drive capability, its voltage output, and the PWM frequency. The IRLZ34N is fine with a 5V drive, if the PWM rate isn't too high. For a 3.3V drive, the IRF3708 is a better choice.
Yes, but only if the voltage you're sourcing with it is no higher than the "high" output voltage from the micro.
