Schematic and bs2 file, Help, Post your thoughts please Mike
···· I assembled this unit as per the diagram using various N+V articles. 4-bit LCD mode works fine and keypad works·for single digit input·but need a little·help please for multiple digits. Another question, can i change the keypad routine some for a 4R X 3C keypad? Iwould like to drop the pullup resistor from pin 15. However, I2C·is·working.·· Note: I am actually using a bs2 homework board Rev. B
value = value * 10 + newKey
If you get a "delete", you'd do something like:
value = value / 10
Note that the above does no error checking or checking for overflow. You'd want to add that sort of thing.
"value" is a word variable initialized to zero and used to accumulate the entered value.
Your circuit is already set up for a 4 x 3 keypad. You can use the same logic for any number of rows and columns.
