How To Control A 12VDC or 24VDC Motor With Board of Education?
I'm just wondering how I can control a 24VDC/12VDC motor with my microprocessor board from parallax. Since these motors require a lot of amperage, the power the microprocessor board produces will not be enough, so I need to create something like in the attached image.
Basically, if I push a button, that sends a signal to close the switch which completes the circuit. I'm just not sure what electric components I need to do this since it requires like two circuits working together.
Start with the Downloads button on the main Parallax webpage. Also, the Resources tab will get you to the Nuts and Volts Columns index.
