Question about PWM vs. high/low signal
I am trying to find a high power (10amp continuous) dual H-bridge to control to drive motors (both going forward and reverse). I found one out of India that had four pins, and depending on which pin was driven high, motor 1 went forward or reverse, and motor 2 went forward or reverse. Very simple and what i need. Yet all the H-bridges I see from companies in North America seem to use PWM.
For instance, Robotics Connection has a 10 amp dual H-bridge on this link:
www.roboticsconnection.com/p-77-10-amp-dual-h-bridge.aspx
which uses high/low for direction, and PWM for speed. I would be fine if my motors were full on or full off without speed control.
My question is this: Can I apply a on/off (0V or 5V) constant signal to a PWM pin and achieve a full on or full off state? Or does a PWM pin, even in a full on state, require the on/off switching frequency? I have a feeling these H-bridges accept PWM because they are meant to be used with a PWM motor controller delivering them signal. But are there any off-the-shelf dual high-power H-bridges that will work with on/off signals from a basic stamp for example.
I know this is a simple question, thanks for the help.
Blake
Blake
- Stephen
