sensor is ultrasonic sensor
Can someone tell me mm constant and how to caculate my sensor is ultrasonic sensor
Post Edited By Moderator (Joshua Donelson (Parallax)) : 5/27/2010 8:03:05 PM GMT
Or, set up a little test and calculate the constant by yourself?
By the way.......don't PUSH and use the pencil icon to add a subject line!
Tom Sisk
http://www.siskconsult.com
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/28029/List/0/SortField/4/ProductID/418/Default.aspx
It shows you how to take the raw sensor reading, and convert it into inches or centimeters. Converting from centimeters to millimeters should not be difficult.
I·hope this helps!
-Stephanie
·· Here is a small change that I did a while back for a customer who wanted to get the same measurements. You can use the following example to get exactly the program you desire.
I hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
