Expand eeprom is it possible?
Hello
Is it possible to use the http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010785·256KB instead of 64KB to expand memory in propeller. I searched the maxim database and i can see that other·characteristics·match·with the onboard 24LC256 -I/ST ? Has anyone expanded the memory of propeller ?
Thank you in advance
You said.
" xxxx - to expand memory in propeller."
It not Expand Memory IN Propeller - It give You only Extra storage capability.
HUB Memory is always 32KBytes and You can't expand it - Propeller always load only that portion of data from EEProm to run.
Regards
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Yours 1 question - YES.
Yours 2 question - Some one on forum experiments with that - Don't know if he ended that project. But it is not so simple.
Some added external MEM - Look on Triblade, Morpheus - Threads.
Regards
Sapieha
