Propbasic: Invalid Parameter on HUB variable in 2nd Task (v99) [Solved]
Bean,
I took the code and added a hub variable 'myval', and tried to increment the value in my 2nd task.
It comes back as 'invalid parameter'.
Also, for fun, in the Serial_RX task, I added
INC RxHead
INC HPntr
And it comes back with invalid parameter for RxHead.
Am I doing something wrong?
Thanks!
Post Edited (Yendor) : 5/26/2010 2:20:38 PM GMT
INC RxHead
INC HPntr
Thanks!
Inc applies to cog variables only.the variable RxHead is a hub variable.
regards
Gerry
Yeap, Gerry is exactly correct. HUB variables are not directly accessible. You'll need to do:
RDBYTE rxHead, temp
INC temp
WRBYTE rxHead, temp
Of course you may not need the WRBYTE if the updated value doesn't have to be permanent.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
