Need some help with Logic for a 3D Printer Project
Hello all!
This is the first post I have made with the forums, and made it here based on a refferal from Parallax tech support since you members have a great rep for figuring out complex projects like this
I am in the process of building a 3D printer/Rapid Prototyper and using the basic logic of hacking a InkJet printer to do most of my work for me. There was another gent that pulled this off a few years back using the Parallax Propeller and had much success turning an HP printer into a flatbed printer. This is my first step in the project. His results are here:
http://www.indoor.flyer.co.uk/3dprint.htm
So I know I need to start with a Propeller chip/board to gain control of my InkJet printer heads. This will be my first fab project, and although I feel pretty technical, it will all be new. If I can manage to control my inkjet printer heads as need be, I will be building a powder bed that my jets will be spraying onto. This method has already been created using a heating element by the folks at CandyFab, and works quite well. http://wiki.candyfab.org/CandyFab_Mechanical_Design
With the printer head, I will need a way to control the X and Y axis of the stepper motors to put the print head into proper place. A method of telling the printer to begin expressing ink, and a method to return the head to a beginning position after completion. I may be able to simply use the printer controller board for this as it will likely require much less programming of the cartridges which are pretty complex.
Once to this point, I will need an array of controllers or chips to tell the bed (Z Axis) to lower a specified amount. A chip or process to drop new powder onto the bed, and another process to push a roller over the bed to smooth out next layer on top of the powder bed. This has been accomplished by CandyFab using many different Zuccherino circuit boards, but I would really enjoy being able to get all of my logic built into just a single or couple of boards if possible.
So, with all this out there, and hopefully it makes since, I am hoping some members can help me to determine what electronics Parallax currently carries that should be able to handle a job of this scope. I am open to all options, and ready to start ordering materials, just not sure what I need yet.
Thanks ahead of time for any advice you have!
CandyFab at work:
Flatbed Printer built from HP parts:
CandyFab at work:
If you haven't done anything with the Propeller before, the first thing I recommend is to get a Propeller kit and work through the labs/education material on what the Propeller is and how to use it. You can do this while you sketch and think through the design. Learning more about the Propeller will help when it comes time to put software into the design.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
I'll be sure to post some drawings here soon on what exactly this will look like, and a much closer view of what steps the machine will be taking for each process.
Any other thoughts on controlling a print head with a propeller chip or other pieces of the project?
