What is the best robotics kit available for $500 or less?
I am looking for a Christmas present for my husband. He works in the field of artificial intelligence. I have seen several robotics kits, but I am unsure which is best for someone who is older (26) and has a lot of programming experience, but not much experience with robotics hardware.
Post Edited By Moderator (Dave Andreae (Parallax)) : 5/24/2010 8:49:59 PM GMT
You'll spend a little more than $400.00 and give him a robot kit that is extremely well designed.
OBC
Are you Propeller Powered?
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
There are cheaper ways to get started like the BoeBot, but, given the fact that he has a lot of programming experience, he will appreciate the capabilities of the Propeller microcontroller. It's possible to start with a BoeBot (www.parallax.com/StoreSearchResults/tabid/768/txtSearch/boebot/List/0/SortField/4/ProductID/296/Default.aspx) and add a PING))) and its matching servo motor and bracket (www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/248/Default.aspx?txtSearch=ping+servo+bracket), then replace the Stamp with a Propeller like the Propeller Protoboard.
Another good way to get started would be the new Scribbler 2 expected to be for sale in August (www.parallax.com/ProductInfo/Robotics/TheScribbler2/tabid/826/Default.aspx). This is a really good Propeller-based introductory robot with a tremendous amount of potential. With its built-in microphone and speaker, it can also be used as a platform for experimenting with speech synthesis and speech recognition using existing speech synthesis software as a base.
Rich H
edit: the original post had links in the signature - one that said "motor boats" and the other a link to online steroids.
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 5/24/2010 10:20:44 PM GMT
John R.
Click here to see my Nomad Build Log
I saw that too. Regardless, the question has netted some quality responses.
Rich H
Thanks.
Post Edited (hys8312) : 5/27/2010 4:59:18 AM GMT
