How to make a line driver to interface a TSL230 light sensor to a Propeller?
Good morning,
I'm interested in making an optical densitometer array out of TSL230s (Light to Frequency converter) but I notice the data sheet suggests that if the output lines need to be greater than 12 inches, it's necessary to use a line driver or buffer. Can somebody please point me to how such a driver is designed? I'll probably need to direct the TSL230 output through about 5 or 6 feet of wire back to my Propeller, and the line driver (which I presume needs to be very close to the TSL230) needs to endure temperatures up to about 158 F (70 C) for long periods of time.
Also, would twisted wire pairs be good enough for this, or would a coax cable be necessary?
thanks for your help,
Mark
Data sheet is attached.
Post Edited (ElectricAye) : 5/24/2010 2:41:05 PM GMT
Mark
pdf
218K
Okay, I'm not experienced with designing transistor circuits, not even basic ones, but I guess it's time to learn. I'll look this up and take your advice on the local voltage regulation, too.
But if you happen to know of a chip prepackaged to perform this sort of function, I'd be much obliged to know about that, too.
thanks, Phil, you are definitely a mood-enhancing forum member,
Mark
Thanks very much, Phil. Your advice is as good as gold.
Thanks, kwinn, I'll have a look at that, too. I just noticed Digikey doesn't have 74LVC1G07 in a through-hole version, so I might have to check out other options.
cheers,
Mark
if the electric noise isn't too big you can use something like this
74HC/HCT7541 Octal Schmitt trigger buffer/line driver; 3-state
If you want super-maximum protection against electrical noise use RS485 and twisted pair cables.
best regards
Stefan
Stefan,
Thank you. This looks like something I can easily solder and understand how to hook up. Indeed, my environment will be low on noise so I think this will be perfect.
thanks again,
Mark
I think you're making this harder than it needs to be. You certainly don't need an octal driver on the transmit end to handle one signal output. The other difficulty with the octal driver is its extremely fast rise and fall times which, without proper termination, could cause ringing and false counts at the receiving end. However, the 74HC7541's Schmitt triggered inputs would come in handy on the receiving end. Here's the circuit I would use:
The Schmitt trigger shown could be a section of the 74HC7541 or any other device with a Schmitt trigger input.
wow, thanks for going to all the trouble to draw that up. I'm embarrassed to confess I still haven't learned how to design anything with transistors so I usually mess up even the simplest of circuit designs.
I understand that with great knowledge comes great responsibility. I promise to learn from this inscription and to use your circuit for only good and never for evil.
I am eternally indebted to your kind generosity.
Mark
