Computing write/read speed — Parallax Forums
KyeKye Posts: 2,200
edited 2010-05-24 13:21 in Propeller 1
I'm trying to do some integer only math using spin and I'm encountering some overflow problems.
Basically I have the cnt difference from the start of writing to a file and from the end of writing to a file. However,·the value goes above POSX.
What I want to do (as if I had floating point) is:
timeDelta = ((stopCNT - startCNT) / clkfreq)
and
bytesPerSecond = (131072 / timeDelta)
The problem with doing this is that if the value is rather low with integer only math I need to scale it up. Buf if I do that every time then if the value is to high I will have an overflow.
Then I also have the problem of SPIN's signed math, if the value is above POSX then its hard to do math in the first place on the value.
So what can I do?
Thanks for your help,
Nyamekye,
    edited 2010-05-24 03:56
    My umath object (attached) might help with the overflow and sign problems.
    edited 2010-05-24 12:31
    You could use a LOGIC ALWAYS counter and use that as your cycle difference (0..N, counter starts at 0). Provided no action exceeds an overflow (e.g. 53.69sec @80MHz) or - even stricter - goes into signed land (26.8sec) that should be sufficient.
    Post Edited (kuroneko) : 5/24/2010 1:34:24 PM GMT
  • JonnyMacJonnyMac Posts: 9,819
    Keep in mind that division is signed and, based on the value on CNT when you grab it, your calculated delta could be a negative value. I just did a blurb about timing tests in my last N&V column with something like this:
    t0 = cnt
    ' code to test here
    delta := ||(cnt - t0)
    As Marko indicates, the is good for durations up to CLKFREQ/2.
    Jon McPhalen
    Hollywood, CA
