newbie question-how do I connect propellor tool to propeller chip over usb??
Hello-
I recently bought and built the Parallax Stingray robot kit. I installed Propeller Tool 1.27 on my Windows Vista 64bit machine, noted that it was installing a usb driver, and connected the usb cable to the completed Stingray robot. I turned on the Propeller board in the Stingray, and I saw the green light come on. The manual says that the pc should find the usb device at this point. I saw no indication of this. In Propeller Tool, I press F8, or Run/Identify Hardware, and I see the message "No serial ports found". So, I thought I just installed the usb serial port when I installed Propeller Tool. I can find no information about this issue doing a google search, other than to install a separate usb driver, which I did and it made no difference. So I am unable to communicate between the pc and the Propeller Chip. Any help would be appreciated!
bc
bc
Leon Heller
Amateur radio callsign: G1HSM
Please let me know if this solves the problem.
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
thanks! that was it. I've never gotten a bad usb cable out of the box like that, but guess it happens. swapped out for another usb cable, problem solved.
bc
