The nerdkit uses an Atmel microprocessor, the same one that's used in some of the Arduinos. It's programmed in C (not C++). You can't program it in PBasic. It would be possible to use (substitute) a Basic Stamp instead of the Atmel microprocessor to control the LCD. In that case, you'd program in PBasic.
- Stephen
