Help With Code for alarm
Hey I was trying to make a alarm for when a chair is removed from a desk, here is my code, my trouble is the getting alarm the alarm to go off or not.
I don't have a basic stamp, I AM The basic stamp 2
' {$STAMP BS2} ' {$PBASIC 2.5} lcd PIN 15 ping PIN 14 baud CON 32 pb PIN 2 light PIN 0 bicolor PIN 1 'if you do not have a bi color then set this to 8 VARs: LcdBkSpc CON $08 ' move cursor left LcdRt CON $09 ' move cursor right LcdLF CON $0A ' move cursor down 1 line LcdCls CON $0C ' clear LCD (use PAUSE 5 after) LcdCR CON $0D ' move pos 0 of next line LcdBLon CON $11 ' backlight on LcdBLoff CON $12 ' backlight off LcdOff CON $15 ' LCD off LcdOn1 CON $16 ' LCD on; cursor off, blink off LcdOn2 CON $17 ' LCD on; cursor off, blink on LcdOn3 CON $18 ' LCD on; cursor on, blink off LcdOn4 CON $19 ' LCD on; cursor on, blink on LcdLine1 CON $80 ' move to line 1, column 0 LcdLine2 CON $94 ' move to line 2, column 0 Scale CON $200 LcdCC0 CON $F8 ' define custom char 0 LcdCC1 CON $F9 ' define custom char 1 LcdCC2 CON $FA ' define custom char 2 LcdCC3 CON $FB ' define custom char 3 LcdCC4 CON $FC ' define custom char 4 LcdCC5 CON $FD ' define custom char 5 LcdCC6 CON $FE ' define custom char 6 LcdCC7 CON $FF ' define custom char 7 RawToIn CON 889 ' 1 / 73.746 (with **) RawToCm CON 2257 ' 1 / 29.034 (with **) chairdist VAR WORD IsHigh CON 1 ' for PULSOUT IsLow CON 0 rawDist VAR WORD ' raw measurement alarm VAR BYTE rawlow VAR WORD rawhigh VAR WORD Inde: SEROUT lcd, baud, [noparse][[/noparse]lcdoff] SEROUT lcd, baud, [noparse][[/noparse]lcdon1] SEROUT lcd, baud, [noparse][[/noparse]lcdcls] SEROUT lcd, baud, [noparse][[/noparse]lcdblon] Author: SEROUT lcd, baud, [noparse][[/noparse]lcdline1,"Author",Lcdline2,"Shane Patterson"] PAUSE 1000 SEROUT lcd, baud, [noparse][[/noparse]lcdcls, lcdline1, "A.K.A", lcdline2, "Tryx"] PAUSE 1000 measure: SEROUT lcd, baud, [noparse][[/noparse]lcdcls,lcdline1, "Click Button", lcdline2, "With Chair"] DO LOOP UNTIL pb = 1 HIGH light LOW bicolor PAUSE 250 GOSUB pingm LOW light rawdist = chairdist rawdist = 0 SEROUT lcd, baud, [noparse][[/noparse]lcdcls, lcdline1,"Great"] PAUSE 1600 alarms: SEROUT lcd, baud, [noparse][[/noparse]lcdcls, lcdline1, "Arming"] PAUSE 100 SEROUT lcd, baud, [noparse][[/noparse]lcdbloff] PAUSE 100 SEROUT lcd, baud, [noparse][[/noparse]lcdblon] PAUSE 100 SEROUT lcd, baud, [noparse][[/noparse]lcdbloff, lcdoff] alarm = 0 PAUSE 500 alarmloop: PAUSE 100 GOSUB pingm rawlow = rawdist - 0 rawhigh = rawdist + 0 IF rawlow < chairdist THEN alarmLOOP IF rawhigh > chairdist THEN alarmloop SEROUT lcd, baud, [noparse][[/noparse]lcdon1, lcdblon, lcdline1, lcdcls, " ALARM"] HIGH light LOW bicolor PAUSE 100 SEROUT lcd, baud, [noparse][[/noparse]lcdbloff] LOW light PAUSE 100 SEROUT lcd, baud, [noparse][[/noparse]lcdblon] DO LOOP UNTIL pb = 1 GOSUB alarms END pingm: rawDist = 0 Ping = IsLow ' make trigger 0-1-0 PULSOUT Ping, 5 ' activate sensor PULSIN Ping, IsHigh, rawDist ' measure echo pulse rawDist = rawDist */ Scale ' convert to uS rawDist = rawDist / 2 ' remove return trip RETURN
Powered by enthusiasm
- Stephen
The maximum number of times the gosub can be called without a return is 4 levels. (On the BS2) Sometimes used in recursive code but I think you really want a GOTO here instead.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
