Hi-Intensity LED light meter?
Several of my projects involve Hi-Intensity LEDs.··· I have been using the PNA-4601M for IR Remote control, and ULN-2003 & 2803s for drivers.· All works well.· I also gang together several ULN outputs with different low-ohm resistors, to·make variable intensity drivers for strings of LEDs.· This too, works.
Over the years, I have accumulated more than few unlabled Hi-Intensity LEDs, and would like to be able to measure their outputs to some·crude, but useful, level of specification.· The most common LEDs I use are Whites, Reds and Blues.· I tried to configure the VT900 Photo-Resistor in various configurations supplied in the book and have not been successful in getting something that will reasonably, repeatably, reliably·measure a wide range of Hi-intensities, Colors or Angles.· I would relish being able to measure mcd ranges from 1k, to 100k, in 1k steps ...·viewing angles from 15d to 75d,·to 120d, and colors.
I looked around a·bit and did not see anything addressing this, might anyone have some suggestions?
Gives you a rough idea without having to take in the different angles at various distance at least when it comes to identifying maximum current to an unknown LED.
For example I have 3 watt and 1 watt luxeon LED's in a drawer from various projects. Can't really tell them apart as they look the same however the 1 watt is much lower in output as you go past 350ma and the 3 watt keeps increasing over 350ma.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Typically, I use a meter and fixed resisitors to approach the nominal specified current rating (and Vf) for the LED. But again, that only tells you when you have reached a maximum current level, or exceeded it. I am trying to quantify the Mcd output of a wide variety of Hi-power LEDs, which may have similar max currents (typical 20-30 ma), but different Mcd output levels (1500 Mcd to 100,000 Mcd).
I understand that viewing angles and color only complicate the matter, but one problem at a time. [noparse]:)[/noparse]
It's written based on the Arduino, but the concepts should translate to PBasic ok. One note... if you look at the datasheet that is eventually linked, you'll notice that there are part numbers listed for versions of the sensor with more accurate tolerances. If you want one of those parts for you're purposes, you can find them at Digikey. Otherwise, you can use the version Parallax sells.
Thanks.
