Insulin syringe logic probe
HollyMinkowski
This is one of those things you see and exclaim
"now why didn't I think of that"
While searching for info on turning the eZ430-F2013 USB dev tool
into a general TI430 device programmer I spied this thing.
It's a logic probe for sm chip pins that really keeps it's
grip and avoids all the awkward slipping you get when doing
something like this. I just have to rig up a few of these!
Here is an image from the site.
Come to think of it, I'm working in a hospital right now. Maybe I'll ask for some [noparse]:)[/noparse]
"Are you suggesting coconuts migrate?"
You can also usually get packages of syringes from your local pharmacy if you tell them what you're using them for. I used to take this route for getting syringes that I used for solvent cements for use with plastic (styrene) models.
With stainless steel, you need to graduate to "brazing" (basically soldering over 450 C). I would also not discount that some needles are assembled with good old fashioned "press fit". There really isn't much pressure involved.
John R.
Click here to see my Nomad Build Log
and apply some conductive wire glue to hold it there.
I have some, but I can't seem to find them on the web site. They have smaller-than-normal handles - a smaller diameter.
[noparse][[/noparse]Edit follows]
OK. I found them.
Pomona part numbers: 6341, 6342, 6275.
http://www.pomonaelectronics.com/pdf/d6341-6342-6375_100.pdf
Post Edited (schill) : 5/21/2010 8:27:34 PM GMT
The Insulin needles are 30 guage.
Im not sure what the diameter is, but they bend very easily.
Also they get dull rapidly. After using one 4-5 times to inject insulin they start to hurt. Dull = Pain
They are designed for Subcutaneous Injection (Under the Skin).
30 Ga is so small you cannot feel them (most of the time) when you push them in.
Intervenious Needles are larger and sturdier.
They need to be to be inserted into an artery or vein.
These are more painful, and most injections we receive are this type.
Interveinous make better probes, but are harder to get as everyone will think you are an addict with a new excuse!! Im not sure how to get them.
I worked at a hospital 25 years ago and I have a few 20 ga needles. I use alligator clips to connect to the meter.
To prevent anyone from using them otherwise I spray painted them flourescent green and pink.
Good Luck
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
BTW, the needles can be resharpened with a whet stone when they get dull.
Leon Heller
Amateur radio callsign: G1HSM
