Counter to Save to eeprom, then go back in 24 hour's and read eeprom. — Parallax Forums
Jeff2Jeff2 Posts: 46
edited 2010-05-23 15:34 in Propeller 1
What I am looking to do is. In the program I sent in this post.
Is there A way to count the # of times pin[noparse][[/noparse]23] is pushed, save the count each time to the eeprom, and then go back into the eeprom and see how many
times is was pushed. Like in 24 hour's?
con
 _clkmode = xtal1 + pll16x
 _xinfreq = 0_500_000
pub Kid
 repeat
   if ina [noparse][[/noparse]23] == 1
           right
pub right
        dira[noparse][[/noparse]0..19] := %11111111111111111111
        outa[noparse][[/noparse]0..19] := %00000000000000000000
        waitcnt(clkfreq/4 + cnt)
        outa[noparse][[/noparse]0..19] := %10000000000000000000
        outa[noparse][[/noparse]0..19] := %11000000000000000000
        outa[noparse][[/noparse]0..19] := %11100000000000000000
        outa[noparse][[/noparse]0..19] := %11110000000000000000
        outa[noparse][[/noparse]0..19] := %11111000000000000000
        outa[noparse][[/noparse]0..19] := %11111100000000000000
        outa[noparse][[/noparse]0..19] := %11111110000000000000
        outa[noparse][[/noparse]0..19] := %11111111000000000000
        outa[noparse][[/noparse]0..19] := %11111111100000000000
        outa[noparse][[/noparse]0..19] := %11111111110000000000
        outa[noparse][[/noparse]0..19] := %11111111111000000000
        outa[noparse][[/noparse]0..19] := %11111111111100000000
        outa[noparse][[/noparse]0..19] := %11111111111110000000
        outa[noparse][[/noparse]0..19] := %11111111111111000000
        outa[noparse][[/noparse]0..19] := %11111111111111100000
        outa[noparse][[/noparse]0..19] := %11111111111111110000
        outa[noparse][[/noparse]0..19] := %11111111111111111000
        outa[noparse][[/noparse]0..19] := %11111111111111111100
        outa[noparse][[/noparse]0..19] := %11111111111111111110
        outa[noparse][[/noparse]0..19] := %11111111111111111111
        REPEAT WHILE ina[noparse][[/noparse]23] == 1
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-05-20 02:38
    If you have a 64KB EEPROM, that also serves as the boot eeprom, you can just write to the upper 32KB's of it. You could just make a variable and increment it every time the button was switched and after a while write that to the eeprom. Or were you talking about writing every single increment to different address's in the eeprom?
  • Jeff2Jeff2 Posts: 46
    edited 2010-05-22 21:23
    I just am using the 32 kB EEPROM, DIP-8. What is the best way to write the program so it will increment it every time the button is pushed?
    edited 2010-05-22 22:02
    So you could hook it up to the same pins that the Program eeprom is on, but you would have to change the i2c address of the other one. Do you want to save every increment to the eeprom in a sequential manner or do you want to keep counting and then after a preset time, dump the contents to a single loaction in memory? I need a little more info.
    edited 2010-05-23 01:17
    I want to keep counting and then after a preset time, dump the contents to a single loaction in memory. I don't know much about how the propeller chip saves to the eeprom, I am just looking for help because I didn't find much about it in the Propeller Education Kit Labs. So I thought if I would ask, someone out there will know. So what I want to know is how to save the count and to go into the chip and read the count to see
    how many times it was pushed.
    edited 2010-05-23 02:04
    Use the Basic_I2C_Driver object in the OBEX.· You can use a location at the end of the boot EEPROM as long as you don't reprogram the EEPROM using the F11 key.· I would suggest using the last location in the EEPROM.
    You read the last long using i2c.ReadLong(28, $a0, $7ffc) and you can write it using i2c.WriteLong(28, $a0, $7ffc, count).· You should follow the write by a call to WriteWait until it returns a value of zero.· You could use the loop repeat while i2c.WriteWait(28, $a0, $7ffc).
    Dave
    Post Edited (Dave Hein) : 5/23/2010 3:02:05 AM GMT
  • JonnyMacJonnyMac Posts: 9,620
    edited 2010-05-23 03:46
    As Dave points out, I2C is very easy when you know what you're doing (that's easy, too) -- just make sure you use the upper end of the EEPROM for storage so you don't corrupt your program.· I tend to use $7F00 as my storage area; it's up very high in the map and not likely to bang into anything (you can confirm with F8).
    On another point you're going to need an accurate way to keep track of 24 hours -- not easy to do when your program is busy looking for button pushes.· That said, you can launch a software RTC into its own coq quite easily; the attached demo shows an easy way to incorporate a software RTC in your programs.
    Jon McPhalen
    Hollywood, CA
    edited 2010-05-23 04:13
    So program would like something like this=
    con
    pub Kid
     repeat
               right
    pub right
    con
      _xinfreq = 5_000_000
    ' _xinfreq = 6_250_000
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
      MS_001   = CLK_FREQ / 1_000
    con
      #0, REG_MS, REG_SC, REG_MN, REG_HR, REG_DY, REG_RST           ' clock registers
    con
      #1, HOME, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR, #16, CLS      ' PST formmatting control
    obj
      term : "fullduplexserial"
    var
      long  rtc[noparse][[/noparse]6]                                                  ' rtc registers
      long  rtcstack[noparse][[/noparse]16]                                            ' stack for rtc interpreter
    pub main | oldsecs
      cognew(softrtc, @rtcstack)                                    ' start "background" rtc
      term.start(31, 30, %0000, 115_200)                            ' start terminal
      pause(1)
      term.tx(CLS)
      setclock(12, 0, 0)                                            ' just like your vcr
      repeat
        term.tx(HOME)
        term.str(string("The time is... "))
        showclock
        oldsecs := rtc[noparse][[/noparse]REG_SC]
        repeat until (rtc[noparse][[/noparse]REG_SC] <> oldsecs)                       ' update on new second
    pub showclock
      dec2(rtc[noparse][[/noparse]REG_HR])
      term.tx(":")
      dec2(rtc[noparse][[/noparse]REG_MN])
      term.tx(":")
      dec2(rtc[noparse][[/noparse]REG_SC])
    pub dec2(value)
      if (value < 10)
        term.tx("0")
      term.dec(value)
    pub pause(ms) | t
      t := cnt - 1088                                               ' sync with system counter
      repeat ms
        waitcnt(t += MS_001)
    pri reset
    '' Resets all rtc/timer registers to 0
      rtc[noparse][[/noparse]REG_RST]~~                                                ' -1 as flag to reset registers
    pri setclock(h, m, s)
    '' Sets clock registers
      reset                                                         ' prevent odd rollovers
      pause(2)                                                      ' ensure reset done
      rtc[noparse][[/noparse]REG_HR] := h                                              ' update time registers
      rtc[noparse][[/noparse]REG_MN] := m
      rtc[noparse][[/noparse]REG_SC] := s
    pri softrtc | t0
    '' Software RTC
    '' -- runs in standard "clock" mode
    '' -- launch with cognew
      t0  := cnt                                                    ' sync to system counter
      repeat
        if (rtc[noparse][[/noparse]REG_RST] == -1)                                     ' reset flag?
          longfill(@rtc, 0, 6)                                      ' yes, clear everything
        waitcnt(t0 += MS_001)                                       ' wait 1ms
        if (++rtc[noparse][[/noparse]REG_MS] == 1_000)                                 ' one second?
          rtc[noparse][[/noparse]REG_MS]~                                              ' clear ms
          if (++rtc[noparse][[/noparse]REG_SC] == 60)                                  ' inc secs, check for 60
            rtc[noparse][[/noparse]REG_SC]~                                            ' clear secs
            if (++rtc[noparse][[/noparse]REG_MN] == 60)                                ' inc mins, check for 60
              rtc[noparse][[/noparse]REG_MN]~                                          ' clear mins
              if (rtc[noparse][[/noparse]REG_HR] == 24)                                ' in hrs, check for 24
                rtc[noparse][[/noparse]REG_HR]~~                                       ' clear hours
                if (rtc[noparse][[/noparse]REG_DY] < posx)                             ' days below max?
                  ++rtc[noparse][[/noparse]REG_DY]                                     '  increment
                else                                                ' else
                  rtc[noparse][[/noparse]REG_DY]~                                      '  clear
    dat
    No, not even close. You cannot simply bash listings together and expect them to work. In your original post you wanted to count the number of presses in 24 hours; my listing showed you how to create a clock. What you could have done is replaced my main loop that
    a) counted presses (these should be debounced/qualified
    b) when a new press is detected, save it to EE (I2C not shown, but there's a lot of code by me and others in ObEx)
    c) watched the clock -- when the time rolled over to 00:00:00 you hit 24 hours and you can display our total and do what you will
    Jon McPhalen
    Hollywood, CA
